Atkins & Hoyle small deck hatches
Hello all,
There was a recent thread on "Atkins Hoyle hatch alternative.” I’m running into the same issue. For a long while both small deck hatches on Grizabella had been very stiff and hard to open or close. When trying to free them up today the pin on the port hatch (above the galley) shattered on its forward section. The aft section is cracked and probably about to break. On the starboard hatch there is no sign of stress on the pin yet but it remains stiff and I’m afraid it will break too if I keep trying to free it up. I’m attaching a few pictures for reference.
I’m considering my options and would love to get feedback from anyone who worked on their hatches. My main questions:
  • The thread mentioned Hammerhead Nautical Systems (www.hhns.ca) but their website is unresponsive and I cannot find their contact information. Are they out of business?
  • If I decided to get new hatches from Atkins & Hoyle (I’ve seen the cost… sigh), are they a perfect drop-in replacement? Looks like it would be their XR90 model: XR 90 Offshore Cast Hatch
  • How’s the disassembly and re-assembly? I only see 4 screws at the corner of each hatch’s base, it doesn’t look like they’re through-bolted but it would be nice to get confirmation: are they screwed straight into the deck? When putting the replacement hatches in I was thinking I would probably re-bed with butyl tape but my understanding is that it works much better with through-bolts.
  • I don’t think I have the tooling needed to re-condition the existing hatches myself but I’d love to hear an informed opinion about difficult that could be.
--nic
“Grizabella”, NS30U - Owl Harbor, CA
I’ve replaced the hinge pins on all three of my deck hatches. They were so corroded that it was impossible to remove the pin in one piece. I also think they look good in black. :grin:
The pictures are captioned.
Google Photos
Thanks Paul. I’d seen your pictures in the other thread, they’re really, really useful. Can you comment on the process of removing a hatch and putting it back in: is it just the four screws around the base, screwed directly into the deck? Did you have to epoxy the screw holes and tap them before re-installing? And how about sealant?
Thanks again,
--nic
Have you considered having the hatches rebuilt ? I had all mine redone winter before last and they work as new.
Hatchmasters in Ct.
Apologies, I just noted that you’re in California and hatchmasters is located in CT. Bit of a drive.
No problem, thanks for the suggestion anyway. If anyone knows of a good metal shop around the Bay Area that would be able to re-condition these hatches it would help! Assuming it’s cheaper than ordering new ones, of course…
Apologies, I just noted that you were in California. Hatch Masters is in Connecticut, that’s a bit of a drive.
Thanks Nicolas. I document everything for just these reasons.
The hatches are all just screwed down into the raised mounting areas which are solid fibreglass so no epoxy coring is required. Just bed them in Sikaflex.
However when I did mine I was very disappointed with the job done in the factory.
Long story… Feel free to skip to the pictures…
The deck liner has a turned up “chimney” that forms the inside of the hatch opening. When the deck and liner are joined this should contact the underside of the deck and be bonded there.
The fast, easy, and safe way to cut the hatch opening in the deck is to drill a hole somewhere in the center, drop a flush cutting laminate type router bit through the hole, and let the bearing follow the “chimney” and cut a perfect opening.
The slower, harder, and riskier way is to just hack a hole from the outside and hope you get it right…which is how mine was done…and they didn’t.
I discovered this when tracking a persistent leak and upon examination discovered that all my hatches were done this way.
Just a warning of what you might find when you remove them. The album shows how you can restore the deck’s integrity if you have this issue.
Google Photos
Wow this is incredibly useful, thanks Paul. And sorry you had to discover this… hopefully mine will be in better shape, I’ll share pictures when the removal and re-installation take place.
I’ve restored all of my hatches and windows as well. New acrylic, sandblasting, new coating, new hinge rods, and new springs for the windows. It’s a very manageable DIY job, and well worth the effort.
I agree with almost everything Paul says, except for one detail: the solid fiberglass underneath the hatches. That wasn’t the case on my boat. Beneath the outer fiberglass skin, there was plywood around the hatch openings. The rest of the deck is, of course, balsa-cored.
I do completely agree with Paul that whoever was responsible for cutting the openings at the factory should probably have visited an optician first! The window openings were cut with exactly the same level of precision. Some are so roughly cut that the window flange only just manages to cover the hole.
Anyway, I wish you lots of success and enjoyment with the project. I hope the results turn out beautifully!
Mark H, N36#25, Netherlands EU
I removed and sent all four of my deck hatches back to Atkins & Hoyle to be rebuilt with new glass. Not cheap, but done right. My larger hatches had many more than just four screws holding them down, but they are all clearly accessable.
When using the Sikaflex to remount them, thought I had enough down for a watertight seal. Wrong.
So I removed three of them that failed the blasting hose test and re-bedded them with even more Sikaflex. Successful this time and no leaks. Just need to trim away the excess Sikaflex, but no hurry for me on that. Sealed the hold down screws no problem.
When removing the hatches, I found using a couple of 5 in 1 tool with a hammer helpful in breaking the seal and then removing the seal’s remnants from the deck and hatches.
Now if only my other projects were this straightforward!!
Hope this helps.
Chris Allen
“Uff Da” Nonsuch 30 Ultra
Tall Timbers, MD
Thanks Mark and Chris! Lots of useful, practical suggestions from you both. More ideas and real-world experiences are very welcome, as they really help with planning the project.
I love my Nonsuch and the overall build quality, but I must say what I’m reading about the “approximate” cutouts is disappointing… oh well. Maybe I’ll get lucky and find they had a different technician with better eyesight in 1985 (when Grizabella was built) :grinning_face: I’ll report back with pictures when I remove the hatches.
Wonderful infor and timely as I am about to undertake the same task. .I was thinking of poweder coating vs paint. More ecpensive but I think it will be more robust than paint.
My hinge pin on the top tends to move out and needs to tapped back so I lube them at that point as well give the hinge latch dogs. With the aluminum on stainless corrosion is always an issue.
Paul kindly giften me some gaskets .
It does seem Hammerhead is no longer in business, but there are other optiins as the size is pretty standard. Atkins is very expensive and service ranges from good to less good.
I’m still in the planning stage of the project and haven’t removed the hatches yet. One thing I’m wondering about: has anyone considered through-bolting the hatches? I’m not a fan of screwing directly into the deck, and through-bolts would let me use butyl tape as the sealant, which I find much easier to work with. It would also make the hatches easier to remove in the future, should that ever be needed.
Presumably this would mean cutting four holes in the liner below for access, but that doesn’t seem too difficult (and they can be plugged later with snap-in covers). I’d follow the usual approach: drill oversize and fill the holes with epoxy before redrilling to seal the core, and use large fender washers underneath to spread the clamping load. Am I missing something? Is there something underneath that prevented the factory from through-bolting?
Of course, this also assumes there’s enough deck flange left for the through-bolts, which may not be the case based on what Paul and Mark reported…
It is almost always possible but I wouldn’t recommend it in this case.
On Mark’s boat with plywood in the deck it would be much easier. You will find that on the 30U there is a good sized gap between the deck and liner in the area where the small hatches mount.
I agree with you that butyl tape pretty much requires bolts or good luck but I also think that most of the trouble people have with the likes of Sikaflex is in the execution, not the material. Use enough, snug it down until it squeezes out evenly, and then let it cure before tightening . It’s not glue. It’s a gasket.
BTW, no need for over drilling and epoxy coring. It’s solid fiberglass.
Thanks Paul, great feedback as always. The Sikaflex you used was their 291?
Either that or Boatlife LifeCaulk.
