I’m the new owner of NS 460 and I’m having an automatic bilge pump installed. What pump do I want and how do I want it installed?
Dan Mills
NS30U sakina
West River, MD.
Dan Mills
NS30U sakina
West River, MD.
If a pro is doing it, he/she should know. Otherwise, a simple on/off/auto switch with a light that supplies power directly from a battery – not through the battery switch. Obviously you need some type of float switch in the bilge. Most pumps come with a diagram.
Dan,
How wet is your bilge? Several inches or dry? I’ve installed a second pump that takes out all the water down to the very bottom. Normal bilge pumps only take out down to an inch or more. I don’t want any water for stuff to grow and smell foul.
https://www.seaflousa.com/product/seaflo-dry-bilge-system/
You can set this to run on any schedule you want and it’s self-priming.
NS30U #396 “Quickbeam”
Good morning everyone,
I have a NS26C that I recently moved down to the Chesapeake Bay. I had a similar question but am more focused on how to plumb an automatic bilge pump? I have a whale gusher pump that manually drains the bilge out a thru hull on the stern. What have people found practical for draining an electrical pump? Out the stern seems like a long way to go. Has everyone put in a vented loop and a thru-hull high on the topside mid ship? Any guidance would be appreciated.
Regards,
Cameron
Cameron Pforr
NS26C #48 Cat’s Cradle
Deale, MD
Yes, through the side with the vented loop. I think mine is about 16 inches above the waterline. Do not install a back flow preventer as it will freeze in the winter unless drained.
How high do you mount the inside loop? I have had my side decks under water on occasions.
I don’t remember, Mark, but it’s pretty high.
Always winterize the pump with antifreeze for the winter. Bob Horne 1989 N26C 248. Encore. Pocasset, MA.
Hi Cameron,
My 26C has the automatic bilge pump plumbed to the sink drain, using a T to that drain line just below the sink. This is how it came from the factory new in 1983. I always wondered why it was done this way, but clearly it is the shortest route for this plumbing and does not require another through hull.
Misty Cat 26C #121
St. Peter’s, Cape Breton
Nova Scotia
I just put in a Sherwood and Water Witch…works very well.
Dan-
There’s lots of different ways to approach your bilge pump setup, almost all with tradeoffs. I’ll offer what I’ve done on my boats. Everyone probably has a different approach- this is my solution. Perhaps it is because I grew up with wooden boats where springing a leak wasn’t that uncommon.
'hope that’s of some use to you.
Dan Weinstein
Look Farther, 30C #205
East Greenwich RI
Here’s another idea to install an electric bilge pump, if you already have a manual one. It may sound strange to you, but hear me out.
No extra holes in your boat’s stern or bulkheads, no T-connections and bilge water bubbling up your sink and… no extra hoses!
Manual bilge pumps contain two valves. They both open in the same direction. When pressurized from the input side, they open up. Electrical submersible pumps are “open” when not running. You can just suck water through them with another pump.
What about resistance when installing them in series? Yes, there will be more resistance. However, if you did get an electrical pump with an output as large as the input of your manual pump, you’ll have plenty of power to push through your manual pump. The resistance of a submersible pump is very minimal.
mark h
n36#25 Cotton Eye Joe
europe, netherlands
