After replacing the heat exchanger on my Beta 25D this past winter it seems the yard didn’t take the time to flush the system with fresh water before draining salt water over the engine rails which are made of steel. As a result , there’s are signs of corrosion developing along the rail.
Any thoughts on best means / methods to stop the corrosion and prepping for some new protective paint? Thnx in advance.
As a separate questions - anyone know the status ( aka costs) of small laser devices to strip rust , etc. And - is sand blasting even an option these days? Is there a small unit available??
