I guess two school of thought. Stuffing box - traditional, Shaft Seal - Modern. Both have inherent advantages and disadvantages. Since moving to the PSS, I have no drips, no unscrewing of the stuffing box while in reverse and no worry. As I am motor sailing most of the time, it gives me confidence that everything is going to be fine downstairs.
Teflon as many know, is a wonderful material invented and manufactured by Dupont. It has a high melting point, chemical resistance, wear resistance and excellent electrical insulation properties. However, it is totally inappropriate for use as a shaft seal. Due to those properties listed above, it will gaul the shaft if it is allowed to over heat due issues with the drive - witnessed around here on a few shafts. Issue could stem from a variety of causes, such as: shaft misalignment, overload, worn cutlass and or other components, over stuffed or over tightened stuffing box. Traditional stuffing works fine as the stuffing material will fail at a much lower temperature in a way acting as a failsafe to indicate issues that need addressing. They should and will drip or seep accordingly. To some, this is not acceptable. That is purely a personal decision as a traditional stuffing is tried and trusted.
For me, when I got a new prop a couple of years ago, it was time to address the shaft and box that was leaking and unscrewing all the time from vibration. That is a great time to upgrade!
Issues with PSS? No issues at all as long as your mounts and alignment are good. I burp mine every time the boat is launched so that the air is let out of the stern tube and allow the lake water to act as the heat sink. The mating surface (seal) of a PSS is much higher than that of stuffing box and truly drip and worry free.
My advice if you are hauling out, have all the replacement parts ready, cutlass, shaft, coupling, bolts and (PSS or new stuffing and hose). That way you are not wasting time. Time = money! Oh, alignment can take 1/2hr or 6 hours. It all depends on a bit of luck. Mine took about 2 hrs in -15 degree Celius in March!
By the way, this was all “learned” to me by a good friend and retired shipwright who is the only person I allow to touch my boat now.
Oh, if you don’t have access to a machine shop, a pair of narrow wedges on your solid coupling will be your friend
Regards,
