So we had quite a few scratches on the dodger windows and were planning of replacing them but ran out of time. SO. I had some Novus a plastic glass cleaner system that over the years I had tried to use by hand to fix scratches to little success.
Then I saw this guy on u tube using a buffer. Holy molly Batman ! In less than a morning all new glass… I’d say a 98% job. Ok eventually it’s needs replacement but for now a great outcome.
So if those scratches and haze are driving you it is a sinple solution. I have a Makita polisher but any 6 inch polisher that has a varible speed will work. Low speed is what you use.
You find Novus in most chandlery and auto supply.
