Richard Westin
Intuition is boat name
Nonesuch 36
Presently in Ft Pierce, Florida
When I initially pressed the rubber “flush button” nothing happened, except once the interior lights dimmed. I dismantled the toilet and found that the loosened pump motor can work on occasion when poised just right, but I cannot not remove the pump. I think the impeller housing is preventing removal. After removing the toiled from the seat I could
see some metal "paddles’ that did not move. I want to remove the pump and toy with it to try to determine the problem. The Installation Manual was not helpful in this regard but has a good exploded diagram. The part number for the pump is Model 160L1912.
Does anyone have advice, esp. as to how to remove the pump?
Richard Westin
Nonesuch 36, Intuition
Presently in Ft Pierce Florida
