Hello—in my first (so far very happy) season with a Nonsuch. I’m very new to diesels and engine repair generally. I’m trying to diagnose and repair a problem on my 1986 NS 30U, which has a Westerbeke W27A, well maintained by the previous owners.
Over the past couple of outings I’ve noticed that the amount water coming out of the exhaust was diminishing, and on longer motoring passages (30-90 mins), the only water coming out of the exhaust was in the form of steam. On the last of these trips, probably about 30 mins of pushing against the current at moderate speed) the temp gauge was just above 200, making me very nervous.
The last time I planned to go out, no water at all came out of the exhaust when I started the engine (it usually starts spitting right away). Cancelled the sail and started diagnosing.
So far I have checked the through-hull, strainer, hoses from through-hull to strainer, strainer to pump, pump to heat exchanger.
I have also replaced the impeller, though it appeared to be in very good condition (see below–I was a little puzzled by the fact the impeller housing wasn’t perfectly cylindrical and that the fins on the existing impeller weren’t all pointing the same way.)
Just before I was about to tackle the heat exchanger, I tried running the engine with the pump/impeller output hose disconnected to see whether any water was coming out. Nothing came out.
Is it safe to assume, then, that my water pump is shot? Could there be another explanation? Is there anything else I need to check?
If the pump is shot, is it something a moderately handy person can replace himself, or is this an expert-level repair? It looks hard to do largely because on my boat the pump/impeller location is nearly impossible to access—we were only able to replace the impeller using mirrors and cameras to see around angles, and had to do a lot of it by feel—even though we have an inspection port in the starboard aft locker to get to it.
Really just looking for any suggestions, advice, words of wisdom/warning/encouragement. It’s my mother’s 80th birthday next weekend, and all she wanted was to go out sailing with me so I’m desperate to get it fixed (or else let her know it’s not going to happen…)
Thank you very much in advance…sorry for the long post!
George Weld
“Lionheart”
1986 Nonsuch 30U #352
Rhinebeck, NY
(attached are pictures of the previous impeller, which looked in good shape but odd fin position to me, and a picture to make sure I’m tackling the right area if I go in to change the raw water pump)
