going up the mast
Nonsuch is great for single handing, so i believe you should be able to get up the mast single handed if you have to. I have seen the TN Topclimber in action and like it very much. I have a home-made version comprised of a climber’s harness and two climber’s rope clutches. One clutch is fastened to an arm’s-reach length of rope to the harness belt, so I can sit in it. The other clutch is on a pair of lines with sliding-knot loops around my feet that I can stand in. I can get up and down the mast myself on one halyard made fast and taught - by standing and sliding up the un-tensioned seat clutch, then sitting and sliding up the un-tensioned foot clutch. This outfit was a gift to me from Trevor Robertson - a friend and occasional visitor in Cape Breton who sails the globe mostly single-handed on SV Iron Bark.
After some practice you can get up and down very quickly, and you have the ability to stand or sit while you are working aloft. As you use mainly your leg muscles, in my case my aging arm muscles are in better shape to handle the wrenches, pliers… and whatever I need to do up there.
Using this climbing method, and a second halyard for the wishbone, I can raise/connect and disconnect/lower the wishbone from its hangers by myself.
You can buy the gear you need for this mast climbing outfit at MEC or any good outdoor adventure store. Match the rope clutches to your halyard.
You can also use the harness instead of a bosun’s chair if there is someone to hoist you on the halyard - and to me it feels much safer than chairs or slings. Also, the climber’s harness comes with several attachment rings for hanging rope or a tool bag.
Regards,
Misty Cat / 26C #121
St. Peter’s, Cape Breton
dcarnrite@gmail.com Nov 01 02:26PM -0700
I’m a relatively new owner of a Nonsuch 26. I bought the boat about a year
ago. And my wife and I absolutely love it.Anyway, I want to get up the mast so I can clean years of accumulated dirt
on the wishbone. Should I have any concerns about using a bosuns chair on
an unstayed mast?
“John F. Iscaro” john@iscaro.com Nov 01 05:59PM -0400
About two months ago I used an A TN top climber to change streaming light
and to say I did it. Went very smoothly. Next stop the top. Btw in 6’205#
Greg Silver Graphic Design
Gregory Silver, B Des, CGD, FGDC
PO Box 178
St. Peter’s, Nova Scotia
Canada B0E 3B0
Office 902 535 3990
Cel 902 631 5050
greg@gregsilver.ca
