Today I disconnected the wire to tighten the keel bolt and discovered the end to be very corroded and was held on the bolt with a hose clamp. At first glance it seems to have a weird insulation so I was hesitant to try to remove a short length to expose fresh wire. Is the purpose to eliminate electrical potential as a measure to avoid a lightning strike?
Also, reading the posts on keel bolt torque, I was intent on torqueing them to 150 ft lbs, but alas I couldn’t achieve that within the confines of the cabin sole.
Ron Weber
N22 MagicTime
Punta Gorda Fl.
