Last weekend I had Mark Powers aboard with me in Ganges Harbour and we took the opportunity to make a couple of videos of the much discussed Hudson River gybe.
Through the wonders of modern e-gadgetry I was able to slow down the faster parts and clearly show what happens to the sheet.
In the first video the wishbone is about 15 -20 degrees abaft the mast.
In the second it is sheeted to about 45 degrees.
https://photos.app.goo.gl/oq5JM7RhH6cPCqed7
https://photos.app.goo.gl/41crppK54epkTLbn9
Notes:
At 45 degrees
- it is not necessary to touch the sheet at all
- the wheel is held at hard over until the sail is all the way around
- the line leaps over any low obstructions and flys well behind the cockpit
- not much way is lost in the process
- no hard catch at the end
At 15-20 degrees - it sometimes helps to lift the inboard end of the sheet a little
- the wheel is spun back to hard over the other way as soon as the sail backwinds to prevent stalling in irons
- the line drags along the pulpit rail all the way but still flys well behind the boat
- more way is lost than at 45 degrees but still no stall
At no time in either scenario did the sheet come into the cockpit area. Centrifugal force throws it out behind the boat.
NS30U #211 Sandpiper
