Jeff,
It’s hard to tell. Knowing how hard it is to pretzel oneself to reach the aft wall of the icebox from the inside, I can see why someone would want to go in that way. So, it’s possible. But, I’ve got a few doubts/concerns.
By any chance, have you seen the write-up on the injection process on pp. 32-33 of the INA’s New Nonsuch Owners’ Quick Guide? This figure from it shows the approach they suggest:
The picture I’ve attached is a cross-section, so the curved part in the lower right hand corresponds to the hull of the boat. It’s essentially a cutaway view from the perspective of facing aft, while your picture is looking at the same thing from the perspective of someone facing forward. This picture shows injections into the inner and outer sides of the icebox, but not the forward and aft sides.
A couple reasons why I’m not sure what you’re seeing are filled foam injection sites. One, there’s no real reason to fill them with epoxy because the foam expanding out of them is enough to seal them. Two, injecting foam from that direction only wouldn’t likely be sufficient to properly distribute the foam around all four walls and the bottom of the icebox. It’d be very hard to get the foam to expand forward far enough, much less wrap around the front.
And, it’d be impossible to tell whether you’d done it right. The way you tell if you’ve injected enough foam is that you work your way sequentially from bottom to top. You inject at each point, wait for expansion to take place, and inject again if needed, until you see foam flowing out of holes at or above the current level. Then you move up. Without holes on each side, there’s no way to tell if enough foam has gone in – and no pressure release if too much has. Excess expanding foam can warp fiberglass liners, crack wood partitions, squeeze out through cracks and make ugly messes.
As the diagram shows, there’s also actually more empty space to insulate on the hull side. The only way to effectively reach that part to inject foam is through the side of the icebox as shown in the diagram.
Another thing that make me wonder is that your picture shows a large, very nicely grommeted, hole in the panel with two large red power cables running into it. Those cables look fairly new. That makes it unlikely they installed before insulation was injected, but installing them after would have been very difficult if the compartment was filled with foam.
The good news is that this large hole would make it really easy to snake in an inspection camera.
