Lost my Halyard up the mast
Somehow the halyard disconnected from the head of the sail and traveled up the mast during tropical storm Ida. Really have no idea how it happened. I dont have back up halyard and honestly cant really see the fitting. Is there a trick to retrieving or am i forced to take it to a yard??
Thanks as always
Eric
Elle
NS 30U #280
Here in St. Louis we hire a crane / bucket lift - $150 or so. It might be a good opportunity to invest in a drone??
Tim in STL
White O’morn NS26U #216
Harbor Point Yacht Club
West Alton, MO
I’ve always thought about this happening on my 26C, and have considered a way to ascend the mast without the need for a spare halyard. The technique I envision comes from my background as a rope access technician. I’m 67 years old now, and I am confident I could still do it, but if I had a much younger helper, I would certainly lean towards teaching that person how to do this. Our masts taper significantly towards the head, which may provide a means of rigging an ascending system using a sit harness or full body harness such as a rope access technician wears. Adding two cinching “choker” slings to the system, one attached to the belay loop of the sit harness, and a second choker sling above that one with a two legged bridle attached to act as foot stirrups. The technique would be to sit into the lower choker so it cinches around the mast. Unweight the feet and slide the upper choker up the mast as far as possible. 1-1.5 feet would be a pretty good throw. Step into the foot stirrups driving your body weight straight up, not back at all, but straight up. Whilst standing in the foot stirrups, hold yourself to the mast with weak hand, and use strong hand to slide the sit harness choker as high as possible. Sit into and cinch the lower choker. Repeat this ratcheting process until at the lost halyard. Attach the halyard to the belay loop, reverse ratchet down a bit till your deck hand has your weight fully on the halyard, remove the upper choker/stirrups system from mast. Loosen the lower choker, but leave it on the mast to act as a safety for the descent. Have your deck hand slowly lower you to deck while ensuring lower choker stays loose. DO NOT allow fingers or any other objects to get between the mast and the loosened choker as it encircles the mast. Hint: make sure your chokers have enough material to jump the running lights and steaming light. If you have a mast mounted radar, you will need to take a second sit harness chocker to jump that.
When you do recover your halyard, may I suggest you do not leave it attached to the head of your sail. Instead, detach it and pin it to the base of a lifeline stanchion, then cinch it up snug and cleat it off. This will keep it from flogging in the wind, trying to tug your sail up, and also makes for a quieter night for your mooring neighbors.
Pat Furr
NS 26C #133
Bandolero
Charlotte, VT
It makes it easier to get local help if you tell us where you are, Eric.
Thanks for the advise as usual, I am in Old Greenwich CT and plan on taking her to a yard. Might be a good time to install a back up Halyard - does anyone have any thoughts on this. Blocks to use etc??
Eric
Elle
NS 30U #280
Old Greenwich CT
If you are in a slip, you could go up a neighbor’s mast, heel both boats and snag the errant halyard with a hook. Or, move the boat to a bridge where you could reach over and snag it.
If a length of the halyard is dangling down the mast, the fishing lure technique might work. First you attach a fishing lure to the flag halyard. Next you raise the lure to the level of the sail halyard and whip the lure around until the hook catches onto the halyard. Then the halyard can be pulled down
At our marina, owned by the port authority, the crew has a 65 foot bucket lift so they don’t climb masts any more. Before this, they would only climb masts which had 2 halyards, one to be used as a safety line.
John Barbour
Nature 26 U
The first time I took La Reina out for a sail the halyard snagged on the radar. In my efforts to free it, I lost it up the mast. It only stopped going up when the eye splice reached the sheave. La Reina does not have a second halyard.
When it happened the tidal swing was about 8 feet during the day. My brother and I took her along side a tall fixed dock. We tied and taped boat hooks, pike poles and extension poles together until they were long enough to reach the mast head. We then used a light line and taped together a noose. We waited for low tide and the went fishing. After about 40 minutes with the tide coming back in and us having to hold the pole at shoulder height we found the magic combination of four letter words and managed to get the noose around the shackle. My sister-in-law pulled on the line tightening up the noose. We then turned the poles to twist the line more securely around the shackle and then gently pulled the halyard down. I had forgotten to open the sail cover. A quick climb down to the boat solved that problem..
Pat’s idea should work. You will need a second sit chair to get past the boom hangers.
Finding a tall bridge with limited traffic might work as well.
The saver option is to hirer a bucket lift if you can get it near enough to the boat.
Good luck.
I curse this string. For more than 20 years I’ve not lost my Halyard up the mast, EXCEPT THURSDAY night! Karma? At anchor, halyard attached to a sail tie on sail.
Sail tie came loose, wind picked up in the night.
Anyone have a capuchin monkey I can borrow?
Bill Evans “Companionship” 30U #465 West River Md.
Would it be possible to attach a weight to the halyard shackle? My sail weighs over 100 lbs. so another pound or two to bring the halyard back down if it gets detached seems worth investigating. Anyone tried this?
Barry Clark
NS 354, Swan’sWing, #71
Urbanna, VA
No monkey, but I have never had a station base attachment come loose! Not as handy but solid and give a handhold at that location, port side station by the mast.
Fred Rachwitz
Concerto
Nonsuch 30 U #445
Harbor Springs, Michigan
Northern Lake Michigan
The only time I remember losing halyards was on racing boats where they were stripped to reduce weight aloft. Woe be unto the crewmember who let one go.
Fortunately my yard is 10 minutes away. They have a crane but no monkey
Bill evans Companionship
