Mainsheet rubbing dogger- HELP!
Jim has a good point, and it’s easy to check.
When you next raise the sail, done while the topping lift is either at its usual position or raised slightly and both choker and mainsheet are slack, take a look at the sail. There should be no scallops between the sail slides and the top should be near (but not at) the upper end of the sail track.
Just a cross-reference in case of interest – I mentioned a few posts earlier in this thread that I was installing a boom extension. I’ve got some questions about it, and don’t want to hijack this thread, so I started a new topic: Installing boom extensions
Jump over there if this is of interest.
