Mast bracket for wishbone hanger
Tom I experienced this a few years ago , As suggested the padeyes are attached through the two thicknesses of the mast at the sleeve . Movement has sheared the bolts between the inner and outer parts of the mast .
You will probably have to upgrade the two 1/2 or 5/8 “ thru bolts before doing the padeye repair which will require helicoils .
All the detailed instructions and materials are supplied by Mike Quill rigging in St. Catharines.
Bob Jenkins
Good News 30U
Tom - a question …
You mention that you left your mast up last winter. Do you mean that it was up when the boat was on the hard ?? Or, was she spending the winter in the water ??
Thank you all for your input. I am going to watch it closely to get through the end of the season, (October) then do repairs.
Tom Beilein
Crackl’nRose NSC318
Olcott, NY
