Mark,
I think if you’re going to do a NMEA 2000 backbone (NMEA is short for National Marine Electronics Association), you’re not restricted to using all from the same manufacturer. The whole point of the standard is to make things “plug’n’play” across manufacturers.
I happen to have all >3 years old Raymarine on my boat, and for no good reason have had that on all my previous boats. So, I have no basis for comparison. I can tell you pros and cons of mine, but I don’t regard them as so stand-out that I’d say you gotta go that route.
One suggestion I’d make is to focus on comments from people who have relatively new equipment. There seems to have been a lot of restructuring and consolidation in the industry. How they used to be in the past may not be reflective of how they will be going forward.
My Raymarine instruments do the job. The installation manuals have been good enough that I’ve been able to put them in myself, and have had no problems resulting from the physical installation, and no product defects. The instruments hold up. The displays are pretty readable if you’re not wearing polarized sunglasses.
The problems I’ve had have stemmed from software. They update the firmware every so often and it pays to keep it up to date, because glitches do get fixed. However, you have to be careful to get the updates for all your instruments and install them in the right order. I missed one without realizing it, and spent weeks trying to figure out why my multi-function display would shut itself off and ten minutes later turn itself back on. The problem went away when I reinstalled the software.
One quirk that I found interesting was that my “Raymarine” wireless wind instruments (actually rebranded after Raymarine bought Tack-Tic) use their own GPS’s speed computation to compute true wind, but no other Raymarine instrument will accept that information. They all want to take the wind instrument’s apparent wind report and do their own computation from knotmeter report. So, even if you go with one “brand” you still can’t be sure everything really actually meshes.
Raymarine used to be a U.S. division of Raytheon. Raytheon spun it off, and I believe it went for a while on its own before becoming a subsidiary of FLIR, which specializes in high-tec night vision systems. They’re now based in the UK. Prices on instruments seem competitive, but the prices of accessories (e.g., cable connectors) strike me as, well, not quite Westerbekian, but still pretty high. On-line tech support has a good FAQs section, and has generally been responsive to email queries.
I went with Raymarine mainly because I started with a boat with no electronics, just holes where they used to be and cut cables leading from transducers. I quickly determined I needed an autopilot because I was single-handing, and got a decent price on the Raymarine autopilot (formerly Autohelm) and course computer. Once I had that, I started incrementally adding equipment, and stuck with Raymarine mainly from habit. I also was concerned about anyone fobbing off a warranty claim by blaming problems on a device’s interactions with a different manufacturer.
That said, with 20-20 hindsight, I’m not sure my brand loyalty was due to wisdom or cowardice.
Hope this is helpful. I don’t think any of your choices are bad ones.
Solar Wind
Nonsuch 26C #143
