Oil Relocation
Well late is maybe better than never. In the past there was some
discussion on relocating oil filters. I managed to find a source,
complete with cross reference tables to filters. Now 6 feet of hose
is a good but he might shorten it for you or you could get someone
like Cat to do that as well.
There are cheaper one out there but not diesel rated.
http://www.trasko-usa.com/oil_filter_relocation_kit.htm
I'm curious as to what size filter fits a Westerbeke 21? Also, it
mentions the only adapters they have are metric and I believe our
engines are SAE.
The site seems to have SAE:
"We also have , 3/4-16, 13/16-16, 22X1.5 & 18X1.5 Threaded Kits, Please email for availability"
Joe Tierney Allegro 1992 NS33 #64 Annapolis, MD
Westerbeke is Metric. It is a Japanese engine design.
Nonsuch 30U Katmando
Hi
Westerbeke is a Mitsubishi block.
The filter is a standard thread with many choices out there.
Wix is one of the best. I use Fram with the black rough coating on the bottom.
Al
Barbcat NS 30C #170 Westerbeke 27(A?)
The W13,21,27, 33 are all a variation of a Mitsubishi diesel block
called a K4D
WIX have an excellent filter look up tool at
http://www.wixfilters.com/filterlookup/
I did see they have a different part number for these engines, I have
used 51334, now they sell a 51064 that has a higher by pass pressure.
Westerbeke
36918
http://www.marinedieseldirect.com/westerbeke/shopping/
WIX
51064 Was once part 51334
http://www.wixfilters.com/productinformation/index.html
Purolator
L14459
http://www.pureoil.com/
FRAM
PH3593A
http://www.fram.com/news/index.html
AMSOIL
SFD20
http://amsoil2.cpinternet.com/
The below is the research I did on oil filters back in 2009. I’ve not looked at it lately but believe it’s reasonably accurate.
Sea Harbour Yacht Club
Oriental, NC
Westerbeke Oil Filter and Part Numbers:
WESTERBEKE - 36918 (Old number is 30220)
AC PF 1127
AMSOIL - SFD20
BOSCH - 72168 (old) 3312 (new)
Canadian Tire 17-17236
CARQUEST - 85334
DENSO - 150-1006
FRAM - PH3593A
GM 12337532
Kralinator L 165A
MotoMaster - 17-1723-6
NAPA - 1334
PENNZOIL - PZ-33
PF 57 (25013451)
PUROLATOR - L14459
WIX - 51334
Yanmar 59206
Fits following Westerbeke engines:
Diesel Engines W 10 Two
Diesel Engines W 12B Two
Diesel Engines W 13
Diesel Engines W 13A
Diesel Engines W 18
Diesel Engines W 21
Diesel Engines W 21A
Diesel Engines W 27
Diesel Engines W 27A
Note: It also is the same filter for a 2003 Acura TL-S
