Has anyone found a source for replacement paddle wheels for the Data Marine thru hull transducer? I pulled my transducer from the mount and put the plug in just before launch.
When the Admiral came down I had her spin the wheel that had a few broken vanes and it worked. So I think I only have to replace the wheel and pop it back in for continued use.
Thanks for any leads.
You can have the transducer I just pulled out - either the whole thing or just the paddle wheel. If you want the whole thing, do you want the full wire run? It was a working pull, and the wheel looks fine.
Wow, that’s very generous of you Jon!
If you can put it in a USPS if it fits his ships box, I’ll take as much as you have of it.
Send me your address and contact information with the unit and I guarantee you I will cover whatever cost you you incur.
My address is,
Brian Cayer
86 Greer Rd., Burlington, CT 06013
