Old Data Marine water speed transducer wheel
Has anyone found a source for replacement paddle wheels for the Data Marine thru hull transducer? I pulled my transducer from the mount and put the plug in just before launch.
When the Admiral came down I had her spin the wheel that had a few broken vanes and it worked. So I think I only have to replace the wheel and pop it back in for continued use.
Thanks for any leads.
Brian Cayer
Westbrook , Ct.
Check out DMI Marine.Looks like they still have paddle wheels. dmimarine.com
Wes Graham
NS26 Puffin
Wenona Md
Hi Brian,
You can have the transducer I just pulled out - either the whole thing or just the paddle wheel. If you want the whole thing, do you want the full wire run? It was a working pull, and the wheel looks fine.
Jon Lewit
N26#115 - Kingston NY
dmi@dmimarine.com. P-6 paddle wheels, $50. Bob Horne, 1989 #249 N26C, Pocasset,Ma.
