I’ve been searching for a manual for the propane cabin heater in my 84/30C, I have found that the company went belly up years ago, and checked the document center. Does anyone have one or know where I might find one?
I have the 6P12a model and I do have the manual. The manual comes with a sheet explaining the difference in the “a” models and they seem minor.
I am at the boat and I have taken photos of the manual pages. But I think it would take me the rest of the day to post it from my phone. (West coast, so there’s a lot of “day” left.) If nobody else posts anything before I get home, I’ll do it this evening or tomorrow morning.
Meanwhile, is this the first time you have used it (new owner)? I couldn’t get mine to work when I first got the boat and neither could the surveyor. Then one day I was pulling my manuals binder off the shelf and noticed a thermostat tucked away almost impossible to find. I set it up properly and had no trouble lighting the heater.
On the other hand, the reset/off/on toggle switch is probably an off-the-shelf part. It has three single-pole positions: ON, OFF, and a momentary reset. If you ohm it out and are sure it’s bad, it shouldn’t be too hard to find a replacement. It will probably have manufacturer and numbers on the body of the switch. If they are defunct you might be able to cross reference it somewhere.
The manual lists a built-in circuit breaker which it claims is next to the ON/OFF/Reset switch, but it isn’t there in my unit. You might check for one on yours. You may need to lay down and look up from below to see it if you can’t find it by feel.
I had a heater that looked like that on my 33. I no longer have the heater but may still have the manual. I will check when I go to the boat tomorrow.
Barbara Melanson
Gimlet 33 14
Noank, CT
Barbara M
Out of pure curiosity, what did you end up replacing it with?
I just signed up with an N30U with no heat down on the Ct River and now the fun begins, sans heat.
Brian Cayer
SV Spirit~Wind N30U 419
Deep River, CT
Brian Cayer,
I replaced it with a lovely pull out waste basket. I never really used the heat much, as I am haven’t stayed on the boat past September.
When everything is closed up we are pretty cozy.
Years ago I was on Bearcat on a cold rainy day when Jack & Jenny put terra cotta flower pots on the stove burners for a little while. That helped to warm things up.
Barbara M
Never mind, I just watched the video.
A picture is worth one thousand words,or so they say!
Godspeed with search for a new owner. And may the wind be always at your stern.
Brian Cayer
Hi all,
Just understood the following messages and the lien for service.
I will call Ernie and have a chat with him.
Hope there is a reset button to ship
All the best
Jean
Third Base N30C 224
Sainte-Genevièeve de Berthier
Qc Canada
I am a retired heating and air conditioning contractor. I went to the NFPA.org website and typed in marine propane heater standard. 15 results piped up. None of the results were associated with the vessel itself. The closest result to marine or boats was:
Hello Ward,
thank you for your reply and you’re certainly right. It might be easier to change the heating unit and upgrade the supply system. I’ll keep looking.
I imagine that the NFPA caadian standar is similar to the ABYC… I’ll keep looking to find someone who can do the upgrade.
Jean Morissette
NS30C Third Base
Montreal, CND
Ernie A. here. I thought that I’d replied to your question a few hours but … I must have forgotten to “post message”. Old age … So, I’ll write it again !!
Ward is totally correct on all counts. In my opinion, the only “best thing to do” is to completely change/upgrade the propane system and, I belive, the heater, itself. Only by doing that will you arrive at safe and correct installation. Personally, I have NO experience with boat propane systems, heaters, stoves, etc. but the Nonsucher community HAS. Many of us have completely been through this process and there is a lot of information here, on the bulletin board and, likely, elsewhere. Hopefully, someone will weigh in on all of this and can direct to where the info is.
So that you know, I believe that the NFPA represents professional fire prevention companies and fire fighters, etc. It has, essentially, very little ornothing to do with recreational boating. The organization that “takes care of” the needs of recreational boaters (sail and power) is, indeed, the ABYC. It is the American Boat and Yacht Council and its standards are accepted and followed worldwide. The only organization that deals with recreational (and commercial) boating in Canada is Transport Canada but they adhere to ABYC standards and work very closely with ABYC. ABYC is the trusted and correct source of information for all of us.
