Our discussions on Companion way steps developed a side branch on propane installations so I thought it mad sense to start a new thread. on the topic.
Here is a link to the 2000 ABYC standards for LPG (propane) installations. I know there have been changes to the standards but in order to see them you have to be a member of the ABYC, which I am not.
ABYC A-1 MARINE LIQUEFIED PETROLEUM GAS (LPG …j30.us › Number › filename › ABYC LPG standard
Here is an excerpt:
A-1.9.5.4 Fuel supply lines shall be protected by close
fitting grommets, sleeves, or sealant of non-abrasive
material wherever they pass through decks or watertight
bulkheads, and the method used shall be watertight.
A-1.9.5.5 Fuel supply lines passing through bulkheads
that need not be watertight shall be installed so that the
bulkheads will not cut, abrade, or damage the line.
A-1.9.5.6 Fuel supply lines shall be continuous lengths
of tubing, piping, or hose from the regulating device,
solenoid valve, or leak detector to the appliance, or to the
flexible section at the appliance.
Here are a couple of good articles on the issue.
Safe Boat propane Installation.htm
The last article has a brief discussion on fibreglass tanks.
