On my 36 I have a Tides Track and a Barient 28+ 2 speed electric winch, the sails go up and down without a problem. I have replaced the masthead and foot block at the base as well, but it worked well prior too. While I have raised the sail by myself it is a chore. I suggest you bite the bullet and get a Tides Track, it may save the cost of a larger winch. Good luck.
Steve Currier
N36 #41
Caper
Thames Yacht Club
New London, Ct
I replaced all of the sail track slides with cast bronze ones, and also used dyneema webbing to make the attachment. The result was fantastic! I was able to raise the sail 3/4 of the way before I had to use the winch to do the rest. Once I get my WinchRite functioning again (I broke a tooth on one of the gears) then it will make the job pretty easy.
I learned a lot at the Toronto Rendezvous from seeing all the boats there. Many people praised the Tides Track, and I can see why. It is a great system. But for now, I won’t need to make that investment on Fortunate.
Thanks to everyone who offered me their track slides - those things are extremely rare. I even contacted the foundry Mike Quill recommended but they weren’t available there either.
Happy Sailing!
NS36 #52 “Fortunate”
Greenwich Bay, Rhode Island
You’ve got what I had !! Bronze slides with the original track. Twice per summer season, I sprayed each slide with McLube. Yes, it’s not cheap but it’s clean and works well. My sail dropped like a rock.
