The discussion, Reading Lamp Bulb , revolves around Brian Godfrey seeking advice on replacing a bulb in his brass reading lamp. He is looking for the correct wattage bulb, considering the enclosed fixture and potential heat issues. Aloki / Oyster Bay NY suggests checking 12vmonster.com for a large selection of LED lamps and identifying the base connection. Rob Cohen “Soave” NS33 Westport, CT asks Brian Godfrey to share the part number if he finds a suitable replacement. The conversation also touches on maintaining the brass fittings, with Thor Powell mentioning the need to remove lacquer for polishing, and Brian Godfrey acknowledging the task but prioritizing it lower.
