I’m looking at refrigeration … has anyone used either the cold keelers by Isotherm or Frigoboat?
How effective are they and what if any issues have you had.
Is there any experience with the automatic speed controllers.
I replaced my original refrigeration system with an Isotherm GE150 air-cooled compressor and a flat plate evaporator in place of the original “ice box” evaporator.
Very happy with it.
I’m not familiar with the term “cold keeler”. Does that refer to a watercooler compressor connected to a thru-hole?
What model boat and where are you?
I’ve had great experiences with the Seafront systems.
Barry Connell
Newburyport, MA
N36 Nocturne
Hi Thor,
Last season ( our first with Soave ) her fridge failed to maintain it’s target temps on hot days. I did a needs analysis and searched for options.
In areas that are very hot ( like Caribbean ) a water cooled system makes sense, if you are comfortable with the complexity of the added plumbing and hull penetration. In more moderate climates, air cooled systems look more attractive. I noticed that Canadian boats often locate their fridge compressor/ condenser in the cabin while boats further north normally put it aft in the engine compartment.
Soave’s condenser is in her engine compartment, on hot days the closed compartment can sometimes reach 110ºF.
To make a very long story short, Soave is a 1980’s vintage boat with a retrofitted 2010’s Isotherm compressor. The system “works” but it is not even close to the efficiency of present day systems. Which have the following advantages :
I’m hoping the next generation of marine fridges will catch-up. If Soave’s fridge dies too soon, I’ll probably look at RV refrigeration equipment as an option. There are some very nice self-contained units that can be powered by either A/C or DC power sources. Dometic CFX2 is a highly regarded portable.
For now we’ll keep nursing our Isotherm.
My intuition is that for a northern boat like your’s, an air cooled condenser will be the favored option. You may benefit from placing it in the cabin to mitigate humidity.
Good luck in your search if you find an option the works for you, please share.
Thor,
My 1987 NS30U has a Canadian manufactured (Coquitlam, BC) Nova Kool refrigeration system, model LT201. The external components are mounted on a shelf behind the stove, and next to the cooler compartment. Better efficiency as it is closer to cooler, and not subject to engine heat. Depending on weather conditions, my two 100 watt solar panels can generate more than enough power to run the Nova Kool refrigeration system.
s/v Breezin’
I installed a NovaKool on a 1981 NS26C.
Main system (coils, compressor) are below the port aft lazarette.
Works great.
Bruce Pennycook
1981 NS 26C
Aleaha
Belleville Ontario
I have the original Adler Barbour from 1984. Not sure about the PO, but in 22 years, I’ve never had to do anything to it (maybe the fan). It’s also on a shelf under the stove. It will still make ice.
Sorry, I forgot to add that.
NS30U, Connecticut
In latitudes about 41 north x 74 west here - I replaced a 30+ yr old Adler harbor with a frigaboat . Amp use went from solid 5A down to 3A . Mounted mine on top shelf in engine room with a fresh air intake to the coil from a cowl along the coaming. Works great a year on.
Gary/ Aloki / oyster bay ny
So after way too much analysis I went with a Frigo Boat air cooled. Keel cooling not worth the effort in the PWN and having everything where is can be serviced is a not to be ignored. The modest amount of heat it will generate is not unwelcome in our climes.
Sea Frost and Isotherm were considered. I felt the Frig automation that controlled compressor speed made more sense in a refrigerator vs the Isotherm approach that attempts to drop the temp when is “sees” more then 13.7V and assumes there is power to spare creating a cold plate out of the contents of the refrigerator by dropping it 6 - 8 degrees. I’m not sure how that would work with solar putting out current besides batteries are a better place to store energy than a frig. Stuck me as a good approach for power boats or fridges with cold pates vs evaporators. Less so for sailboats using evaporator plates.
Nigal Calder and others seem to feel in smaller units evaporators are more effective than cold plates. Keel cooling helps in the tropics.
Sea Frost and Frigo placed well in a PS review. All three were very responsive to questions I asked.
https://www.practical-sailor.com/wp-content/uploads/2020/02/PS0609_fridges.pdf
