Replacing sliding galley plastic panel
One of the plastic panels in the galley on the starboard side is cracked. I’ve been ignoring it because I don’t see an easy way to replace the panel. There are not obvious fasteners to remove trim that I can see. I’m hesitant to get into this and end up milling new trim. Anyone have any suggestions?
Do you simply lift up the sliding plastic piece (similar to the way a screen door operates)?
Hmm, I haven’t tried that! I hope that is true.
I haven’t checked on the Nonsuch but other boats I’ve had used a similar system. The plastic channel that the plexi slides in should be removable from the inside. Usually they are screwed into the base of the channels.
Just lift the panel and tilt the bottom towards the inside of the cabinet. Start with the most inside panel.
Thanks Bill,
I’ll try this when I’m back at the boat this weekend.
Yes, it’s much more simple than at first glance. They pop right out! Thank you
