I’ve was avid dingy racer for many years and have been hesitant to return to racing with Soave because I didn’t believe she ( or I ) was ready to perform credibly.
One of my concerns is weather helm. When close hauled in moderate wind last season I needed to apply about 1/4 to a half turn of steerage to keep Soave on course. I was fighting weather helm. Very frustrating when your goal is velocity.
Over the winter I pondered this and came up with a plan to address it, by asking myself what would I do in my Flying Scot… increase forward mast rake.
Unfortunately I didn’t see a way to do this on Soave.
Also over the winter I also set out to address mast wedges that would “bottom out” before fully snugging the mast in the collar ( separate but related issue). The solution was to extend the tapered portion of the wedges up a bit by cutting into the mast shoulder and removing about 1/2" of material ( giving the wedge about another 1/2" of travel ). This change gave the wedge about another 3/16" of thickness when bottomed out ).
I modified half of Soave’s mast wedges in this way and marked them for use in the aft sections of her mast. This ( in theory ) would give Soave an ever so slight increase in forward mat rake. It would also permit wedges to fully sung the mast in the collar.
Yesterday was the first day I was able to test with ideal control conditions.
- Steady moderate wind ( 12 knots )
- Same sail that I used last season.
- Flat sea.
Earlier this season I had the the general feeling weather helm was reduced, but I hadn’t really quantified by how much till yesterday. ( HERE ) is a video of Soave’s autopilot easily steering a close hauled course in 12 knots with full main. Before the change these conditions would have required a full quarter turn ( or more ) on the wheel.
Unfortunately my speed sensor in not functioning again… so I don’t have a solid assessment of improvement in boat speed. Based on SOG from my plotter it’s about .25 knot improvement.
The only downside I’ve encountered is that under 8 knots steering feels awkward because of slight lee helm. But I think I can get used to it.
Has anyone else experimented with subtle changes in mast rake ? Did you get similar results ?
