SpeedSeal Raw Water Pump Cover
Good day,
My effort to replace the impeller on my W21 has led me down a bit of a rabbit hole. Removing Removing the raw water pump cover on the W21 was a real PITA, so I looked in the archives and saw the suggestion that you should replace the cover with one from SpeedSeal to made life easier. My Current pump is a JMP JPR-WB08IP - that must have replaced the original Sherwood or whatever some years ago. I tracked down SpeedSeal, and they refer you to Parts4Engines in the UK. They have nothing for Westerbekes, or JMP, or Sherwood, etc.
Has anyone gone this route in the past few years and know what kit might work? The archive postings on this were very old.
(the current impeller actually looks OK, so the poor water flow problem is probably something else, but as long as the cover is off…)
Jon
Hi Jon - I have a speedseal on my NS30. It is convenient as far as taking off the impeller cover. Instead of bolt heads there are textured round heads on the cover. I wouldn’t say it’s a game-changer. That said, the company is no longer around so they’re not available for purchase unless you find one on ebay.
Yes, that’s what I thought too, SpeedSeal is out of business. However, at my mechanics suggestion, I modified my pump by installing two studs on the pump body so you can more easily put the cover back in place. Then reinstall the screws, and nuts on the studs. I believe the screws are metric on the Westerbeke. I cut the heads off some metric screws to make the studs, and installed them in the pump with some Loctite. You’ll also have to buy some metric nuts, get extras in case you drop them when installing pump cover.
I was happy to find the the previous owner had installed a speedseal. The only downside is that the o-ring that comes with an impeller kit from Westerbeke doesn’t fit the speedseal. I was able to order replacements from parts4engines.com but I had to e-mail them to find out what to order. They were responsive and given they were shipping from the UK, prompt. Be sure to carry spare o-rings. They won’t be at the hardware store.
Thanks for that advice. I just sent the pump cover plate dimensions off to those folks so they could find the appropriate match. They seemed very responsive. I am hoping it will arrive before any hard freeze (the current pump has the cover off…).
I’m wondering why removing this pump cover was a PITA on a N26C with a W21? On this boat the pump should be right there on the front of the engine after you remove the stairs. The N30 owners have their engines in backwards and this makes the pump very hard to get to.
In any case, on the top of the heat exchanger there is a brass bolt head. This is the end of the zink. Carefully remove it !! because if you knock it on the side of the hole an old zink will break and fall in. Remove it and see if there is anything left, it should look like a short pencil. When they aren’t changed regularly (every 5 to 10 years in Lake Ontario?) they get old and if not removed carefully they fall inside and break into chunks which block the heat exchanger tubes. Over years you can have lots of chunks in there. Also broken vanes from old impellers tend to partly block the heat exchanger tubes. The fix is to remove the end caps and clean out. If you only do one end cap start with the one at the zink end. You can make your own gaskets out of gasket rubber if the old ones are brittle. If you need to remove the heat exchanger you may have to buy three new hoses from Westerbeke.
Also if you have winterized the engine already don’t fully install the impeller until the spring. Mine used to last just two seasons until I started to partly remove it in the fall and reinstall in the spring (very easy on a 26C). It’s a few years now and the vanes still don’t have any cracks in them. Sitting in one spot all bent over for half a year was not good for the impeller.
Sorry Jon. I mistook your Kingston for the one on Lake Ontario in Canada. I have no experience with raw water pumps and heat exchanger zinks that may have exposure to salt water. My guess is that the zinks should be looked at even more often.
I find that the zinc in my W33 in salt water lasts about a season. It is very pitted and spongy after four months, and very fragile
Hi Tom,
The salinity of Hudson River water at Kingston, NY is pretty low… the salt line is about 30 miles south near Beacon, NY.
Good explanation of the process !
Rob…
Tom,
On my 26C the raw water pump is tucked away behind and below the alternator with the cover facing the back and it’s quite close to the back of the starter. A tight space even for a right angle screwdriver but quarter turns with a wrench worked. Whoever designed that for a part that needs periodic access hopefully lost their job.
Thanks for the details about the zincs in the exchanger - most likely they need attention and are possibly a contributing cause of the bad flow (the impeller looked good). I had the exchanger descaled a couple of years ago and was not expecting a problem there.
And Rob is quite correct - the lower 150 miles of the Hudson River is technically a tidal estuary. The brackish water ends 60-70 miles up, so Kingston is fresh water. (the river is tidal and flows backwards as the tide works its way up).
