I installed a Tides Marine strong track on my Nonsuch 30C today. On my 30C the tack attaches to a padeye which is bolted to the mast a few inches below the track. Because the new track extends about two inches off the mast, the tack will now be chaffed by the track. Has anyone else experienced and solved this problem?
Bob McPeek, Pau Hana, NS30C
I installed a Tides Marine Strong Track, on my Nonsuch 22, 7 days ago. I am baffled by your description. Perhaps some time this week we can compare installations, after all, our boats are a short walk from one to the other … (grin).
John Foster
Blueberry, 22, 48
Bob McPeek wrote:
My track was also too long but I cut it to length with a hacksaw so it matches the length of the mast track. I secured it using the existing threaded bolt hole at the track base. So far it’s been on 2 years now without problem.
Joel White
NS 30U #303
Rumaki
It sounds to me like the first slug above the tack is to close to the tack. My Strong Track doesn’t have that problem at all.
Hi
My original track was NOT mounted on an aluminum “pad”. Perhaps this the source
of your problem.
Al
Barbcat NS 30C # 170
I think there is some confusion on this thread pertaining to “Track” and “Tack”. The bottom of the Strong Track is attached to the existing metal track at or near the bottom by a screw. The sail tack cringle is attached to the padeye via a shackle.
IL GATTO NS30U #221
Oriental, NC
