Thank you everyone for the advice and info, it does seem like bonding to the mast is the proper way to fasten things, but these Ronstan aluminum track systems are very expensive, perhaps as much as $10k for cars and track suitable for a sail this large, so I’d like to find a way to reuse the Tides cars I already own. Bonding a stainless T-track to the mast to run a Tides track over may be the solution.
I have received two technically detailed e-mails from Dr. Ted Van Dusen, and will put the full text here in case the info is useful to others. Lots of his information is in fact Nonsuch specific, and lines up with the idea that bonding is the preferred method to attach things to the mast, but he mentions using a two part methacrilate adhesive:
Email 1:
I’m sorry to hear the fleet is having trouble with the masts that I designed and made for the the Wylie 30’s. Tom ordered the masts unfinished and I am not aware of the details on how they were outfitted. We have never used pop rivets on any mast that we have built, no matter the size. I am also not a fan of the tides track because the the length of the track for a WC 30 varies about 3" over the range of normal sailing temperatures and the mast hardly changes at all. I learned this when building our first Nonsuch 30 mast, using the tides track and the track buckled between the fasteners and wasn’t up to the loads of the Nonsuch with a considerably higher righting moment..
I was concerned that Tom might not be familiar with carbon masts and discussed the importance of proper installation of fittings on carbon masts. In order to reduce weight aloft and increase the righting moment, I tapered the diameter and wall thickness of the WC 30 mast so it had a nearly uniform stress when near the maximum righting moment. A few years later, I was asked about adding a spinnaker and I said that the spinnaker halyard had to be below 80% of the distance from the deck to the masthead and small enough so that it did not overpower the rig in windy conditions.
If you were to load up a well designed carbon mast until it broke and then repeated the test on an identical mast at a lower load for 10,000,000 cycles, you would find that it would find that it would fail between 60% and 80% of the load applied to the first test. If you did the same test with a aluminum or steel mast, they will break at 10% to 20% of the one load test. With a carbon mast about 60% the weight, no corrosion, and lasting several times longer, it seems like a dream come true. If you drill a small hole in in a round mast and put a compression load on it say from the halyard and rigging the stress on the sides of the hole will be three times the stress on the mast. If you enlarged the hole to 5% of the circumference, 95% of the mast would carry the load so the stress would increase only about 5% to about 3.16 the stress. Even a very small hole matters! Metals are ductlile and deform, reducing the stress near the hole. For the recreational sailor who avoids storms, aluminum masts last decades. Serious ocean racers tell me that they expect to replace their alunimun after 10 tears. When carbon reaches its strength limit it just breaks. Whenever we have to drill a hole in carbon, we gradually build up the thickness of the laminate near the hole, orienting the carbon to the load plus a safety factor so that the stress is well below the failure point. You can see a buildup in thickness around the chocker on the WC 30. We always recomend that the laminate be thickened where there is a hole. It is an extra task; however, it is well worth the effort in safety and longevity. Carbon also does not like abrupt changes in thickness. If you have any questions, please give us a call.
Regarding the screws in the holes in the mast, where the mast is in compression all the time, it is a lot better than nothing. Carbon is so rigid that any small gap between the screw and mast will allow movement which will increase the stress. Filling the gap with epoxy does not help much since the epoxy is much more flexible than the carbon and only 2% the strength. I recomend laying up a stack of carbon the thickness of the mast plus a little, cutting and sanding it to a slightly oversize tapered plug, fileing the holes in the mast to fit the plug, tapping the plugs in with epoxy, sanding the mast several inches above and below the holes down to the carbon, and laying up layers of carbon to a thickness of 1/3 the mast thickness, tapering down gradually in all directions. The mast has 75% of the fibers verticle, so if you can find both woven and unidirectional carbon fabric, it would make sense to alternate vertical uni and fabric layers. If you are having trouble finding a small quantity of the carbon, we can send you some.
Good luck,
Ted Van Dusen
Email two:
Near us us a Nonsuch 33 that has been doing a lot of off shore races incloding over a 10 Bermuda Races. He lost aluminum masts in the process due to fatigue cracking. He came to us for a Carbon Mast after seeing over 40 of our carbon masts racing in their annual regattas. We made him a carbon mast with a Harken anodized aluminum mast, because they are ovebuilt. Before the mast was painted we faired the mast and laid up a 3" wide strip of 8.5 oz fiberglass tape and epoxy where the track goes down to insulate the track from the carbon (about .9 V if it touches carbon and salt water). We sanded the glass with medium grit paper to get good adhesion and bondeded the track down (after washing the track with IPA, and lightily sanding with 320 grit, and used the strongest methacrilate adhesive we could find, Plexas MA320). The adhesive is squeezed out of a 2 part gun and has a 8 to 10 minute working until it starts to harden, so it is important to have everything marked out and 3 people to handle the track. We hold down the track with 1.5" wide masking tape at each end and then 6 to 8" apart while someone is sighting to see it is straight. It sounds scary, bud we never had any difficulty even outdoors in the sun and 80 degrees. You might want to consider this for your mast. You should be fine with the small line of holes covered by the glass and aluminum track reinforcing the area and save a lot of work. Once the track is down, all that you have to do is a little painting.
We used this system on the our around the world single handed masts and the tallest mast we made, 107 ft long on the Spirit of Bermuda and we just put one 20 foot track down after another and had everything done in an hour and a half with three people. This carbon mast was hit by lightening 4 months ago after 23 years service and shipped to us for untrasonic inspection. The lightening hit the top of the mast and vaporized the resin in a 3" diametern circle less than .1" deep, leaving undamaged carbon fiber and the same thing at the mast step. The ultra shoud found 9 very thin voids in a line between the top and bottom that were .5 to 1.2" long and .5" wide in the middle of the laminate. After some research, I decided that the way the carbon was woven together continuous from the top to the bottom it couldn’t go anywhere and it would do more damage to try to repair it. She sailed home in a windy Bermuda Race this year with no difficulty.
Ted
