Tankless Water Heater Replacement
Looks like I am going to need to replace the original on-demand water heater on our 33 year old 30U. The main burner refuses to fire up when we call for hot water. Given its age and its now frowned upon reliance on a pilot light, lI am not inclined to fiddle with it much if it can be easily replaced with one of the ventless Excel units that some of you have installed. If you have recently installed an Excel unit and can share the particulars with me (model number, any installation issues, etc.) it would be much appreciated. Thanks.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
I think most of us have this one. https://excelonlinestore.com/product/used-and-pretested-excel-tankless-on-demand-gas-water-heater-vent-free-propane-lpg-unit/
They are basically drop in and even use a couple of the same screw holes as the Paloma. My boat had a chimney over the Paloma that I left in and connected to my Excel with a floor heat register boot from the hardware store.
Cowichan Bay B.C.
Thanks Paul. I figured that was the model based on its capacity. For some reason our boat has a Rinnai, not a Paloma but they must be very similar. The Excels seem insanely cheap, < $200, but their reviews are generally good.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
The link I sent turns out to be reconditioned but Camping World has them at $209USD. They had the best price when I got mine.
Thanks again.
Thanks for the info, Paul. Our Paloma didn’t drain last fall but did a nice job of it when the water was turned on. Apparently the flow control valve stuck and didn’t let the drain do its job. Fortunately the cracked pipe was visible and not too bad to fix. However, it uses a pilot light and is 34 years old with significantly reduced flow. I will try to find an Excel replacement.
Alan & Tracy, Corvus NS30C, BPYC Toronto
You could take the opportunity to gain storage in the galley, increased ventilation and a heater with no moving parts by going to a engine driven one. Pictures available of mine which is a Force 10 unit.
~~~~~(\_ ~(\_ ~(\_~~~~~~~~~~
Just a thought David. Does your boat still have the tee in the propane line under the galley floor? This might be the time to fix that while you are changing out the water heater. I was surprised to find it still in Sandpiper when I bought her in 2018. I wonder how many surveyors let is slide or didn’t notice it.
That’s something to consider Joe but hard to beat the cost and ease of going with an Excel replacement and time and money being in decreasing supply for me.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
Our gas supply lines T outside the propane locker somewhere, not sure where, but I am sure it is hard to get at. I doubt our propane locker meets current code either. None of these things were noted by our last surveyor in 1998. BoatUS has not required us to provide a survey since then. Maybe I’ll wait until they do.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
David,
I had restarted a thread a few months ago asking for advice on the same issue ( https://groups.google.com/d/msg/INA-Nonsuch-Discussion-Group/4lRftLcjmsg/9ii80uXRAQAJ ). My 30U #516 has (had) a Wolter unit with a water leak and it was clear that the unit had been repaired numerous times before. Many members offered very helpful advice including Joe who suggested the engine system. I spent a week weighing the pros and cons of each option and ended up deciding to replace the unit with a new Excel system. For me the on-demand propane system is a better fit for how we use our boat. At the time Excel was out of stock of their “Tankless On-Demand Gas Water Heater VENTFREE – Propane (LPG) – Low Water Pressure Startup” unit for $220 but they sent me an email when it was available and I received it a few days after ordering. Their customer service is excellent.
I installed it last week and it was an easy job taking me only a few hours after I had the correct water line fittings purchase at a local hardware. The mounting hole pattern on the Wolter did not line up with the Excel like I’ve read about the Paloma’s but the old holes will be easy enough to plug and refinish. The new unit physically fit perfectly and although “vent-free” I was able to use the old exhaust hood to connect the output of the Excel to the charlie noble. I would be happy to discuss over the phone if you want a more detail.
Now my two cents worth on safety which is the primary concern for running a “vent-free” system in the boat.
I would never use this system without a working marine grade propane detection system. A friend of mine lost his life recently in a propane accident on his boat while using the stove/oven and since that time everyone in our club has installed a system in their boat.
I would never use this system without a working marine grade carbon monoxide detection system. Even though the unit is “vent-free” it isn’t a risk I am willing to take. I also want to fall asleep without worrying about waking up in the morning.
I would suggest connecting the exhaust on the Excel to the old vent in the cabin top. Any exhaust byproducts you can get out of the inside of the boat only makes it safer even though the manufacturer states that is is fine without that.
My boat is equipped with 2 separate propane hoses running from the cockpit propane locker to each appliance (stove & heater). This is the current ABYC standard and if your boat has a tee fitting outside of the locker (inside the boat) I feel strongly that you should change that. This was the cause of my friends accident when a leak developed between the tank and the stove.
The solenoid and tank valve should be closed after each use of either appliance and only reopened when ready to cook or heat water.
The system should be leak tested regularly to make sure no leak has developed in the line(s) running through the inside of the cabin. This is as simple as closing the solenoid, shutting the tank valve, and noting the pressure on the gauge which is downstream from these. Leave it for an hour or so and check the gauge again to see if it has gone down at all. A leak free system will still have very close to the same pressure as when it was closed off. My system loses a few pounds of pressure after several hours. In a hose with such small capacity this indicates a very small loss of gas. A leak where the system pressure goes down quickly tells you that propane can enter the cabin whenever you are using one of the appliances.
It’s my feeling that with the proper detection systems installed, up-to-date gas lines, and regularly checking the entire system for leaks that you have a very remote chance of having an accident. This, plus the way we use the boat, and cost were the reasons I ended up replacing the old on-demand system with a new Excel.
Greg Doyal
NS30U #516 Challenge
Grosse Pointe, MI
Greg,
Well written and very meaningful.
Butch
Butch Garren
Nonsuch 30, #196
Whiskers II,
Solomons, MD
I never had any intention of using my Excel “vent free” but checked it out when I was installing it, just to see…
No one would ever keep it that way longer than it took to rig a vent! You get a LOT of very moist heat that would drive you out before the gasses could kill you, even if they could.
I also second the thought that no one should have any propane on their boat without the appropriate sensor / solenoid system and a carbon monoxide / dioxide sensor.
Thank you Butch.
Greg, Thanks for sharing your recent experience with Excel. We were hoping to limit our boat maintenance expenses this season. Nice try. Yesterday the water heater goes on the fritz. Today I find a rodent has chewed a hand-sized hole in one of the tubes of our inflatable dinghy. Someone said life is what happens to us while we’re making other plans. Still nothing as fun as messing about on boats.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
I believe that it was Mike Tyson who said “Everyone has a plan until they get punched in the jaw.”
That’s a good one. I’ve heard mouth and face as the landing site of the punch too. Dave
Furthemore, David, as you head down this perilous road, you will discover that this a truly “tankless” pursuit.
I am sure that I speak for many when I say…
“Tanks a lot.”
Ed Collis
ORION VII
NS30U (For sale)
The quoted wits have nothing on our own Nonsuch cunning linguists.
David Young
Bay Cat, 30U #402
Suttons Bay, MI
USA
