Throttle cable length
Murf Hudson NS 30u
Too Your Shore #472
Rockport, Texas
I have a measured throttle cable length of 122” (no slack). Does anyone know actual length and where to order from.
This was discussed about 1-2 months ago, check the forum for more details. I believe 8 ft will work, but I installed a 10 ft cable because 8 ft was out of stock. The brand was Teleflex Marine.
Recent conversation was ( HERE ). It was about a shifter cable… but same idea and length as the throttle cable.
( HERE ) is the part I used on my N33 to replace a broken shifter cable.
I think for a N30 you can use an 8’ cable ( HERE )… depends on how it’s routed.
My throttle cable has a clamp that adds a resistance so the throttle stays steady when set.
