Hello All,
This seems to be a different issue than my recent post about the slight leak of transmission fluid from my Hurth 150V transmission.
Over the last two weekends, when I put the transmission into reverse when the engine is at idle rpms (about 800 rmp) the engine sounds as though it may stall, and when I throttle up to get some power/thrust the engine barely climbs to 1000 rpm no matter how far forward I push the throttle. I do get some reverse thrust, but it is weak.
But, the problem is not consistent... sometimes it seems fine, other times the above happens.
1) I put my GoPro camera under the boat to look for an entaglement... best I could see as it is a bit murkey, is the prop and shaft are clear.
2) transmission fluid is at the correct level.
I havent had a chance to look at the couplings while in reverse.
Could this be an alignment problem?
When I had a fuel pump issue in July, I also had the mechanic re-stuff the stuffing box. At that time he said that the propshaft appeared to be slightly misaligned. I was a bit surprised at this because in the Spring of 2016 when the prop shaft was replaced, the yard had to remove the strut that houses the cutlass bearing, reglass the hull, and reattach the strut to get the correct alignment because they said the alignment was too far out of adjustment to do it from the transmission end...
Could it just be a bad cutlass bearing? That too was replaced in Spring 16.
Or does this sound like a transmission failure?
Forward gear seems to be working fine.
Thoughts on how to narrow this down?
Thank you,
1987 30 Ultra 430
Liberty Landing Marina
