Clunk going into gear
I just bought a 26C with a Westerbeke 30B Three and a JS transmission. I know it has a 2 blade folder as I saw it during the survey, but I won’t know what make until I haul it out in about a month.
In any case, there is a big CLUNK when going into gear. Fwd or reverse. I hope it is the blades of the prop flipping out and not the transmission.
Is this normal? I have sailed for decades with a Hallberg-Rassy and a fixed 3 blade and never heard anything going into gear.
Advice will be gratefully accepted.
Dave DeWolfe
NS26C #150 “Ascension”
Marriotts Cove, NS
Hi David,
Chancy has a Flex o Fold 2 blade prop and there is a distinctive clunk when it begins to spin. I find it quite reassuring. There is a substantial plastic bumper for the blade.
Welcome aboard.
Mike Jennings.
NSC5 Chancy.
Port Moody, BC.
Welcome to the club.
A test. When you are at the dock tied off put in gear - forward (you should hear your clunk ) give it a few seconds. - put in neutral. Give it a few seconds - Put it back in gear. If you hear a clunk again - it may be the transmision. (Because all this test is with the boat not moving. The prop should stay in its set position for going forward. And if its prop Clunk the clunk should be much less or not at all. )Transmision clunk like that could be damper plate abuse from PO.
Good luck. Let us know.
Maybe a silly question but is your idle set a little high?
Idle is 1000-1200 RPM. Engine manual specs 1200 as idle. Odd, as the Volvo D1-30 in my previous boat set idle at 850.
From ptotos taken during the survey, I think the prop is a Martec.
1200 is way too high. 850 is what It should be. I don’t care what any manual says!!
My engine is a Westerbeke 35-D3, 31HP. I’m guessing its similar to your 30B. My manual also says idle of 1000-1200 RPM. But I just started my engine and checked, and it idles nicely at 650 RPM, and no clunk with my folding prop. I’m with Joe, 1000 RPM is way too high.
‘87 NS30U Breezin’
Vancouver BC
I get a distinct bump sound when shifting into gear at about 600 rpm, no desernable sound to the opening of the the Gori two blade… But I think that the engine sound and vibration would mask that event
Thanks for your comments … I will set my idle lower (say 800) and see if that fixes things.
Dave DeWolfe
NS26C Ascension
Marriotts Cove NS
Hi Dave,
After reading this string I contacted the BETA dealer and asked for his comments. I heave a 30 with BETA 25 and Seaprop.
Current idle speed is 900rpm (900-950 is spec.)
Reduction is a little more than 2-1.
There is a clunk when the blades deploy but not alarming and the clunk is in the prop not the gearbox (I tested it at the dock and there was no clunk).
The dealer said that I would be fine dropping the rpm to 800-850 provided there is no roughness in the idle.
I plan to give it a try.
All the best.
Mike Jennings.
NSC005 Chancy.
Port Moody, BC.
It was the folding prop … Now replacesd with a 3 blade Campbell Sailer
If it is the Martec prop, this could be the two blade , non geared folding prop. The blades move independently. When the shaft stops the blades will swing wherever they want and the top blade flops down to the closed position. Bottom one hangs down (unless you are sailing fast enough to lift it). Put the transmission in forward and this top blade snaps up and goes clunk.
Going into reverse the blades are opened by centrifugal force and the clunk is less if you are at low idle. In reverse with normal rpms this prop didn’t work very well and I guessed it’s because the blades would partly close up.
26C #28 North Star
Penetang
