Pretty good winter learning curve project.
Nice thing to have.
Here’s picture of one that my rigger set up for me as an alternative to the choker turning block on my boat.
I’m not totally satisfied. It would be better to have both positioning lines come off the ring. As it is, the horizontal line wrapped around the vertical line is prone to riding up. I plan to fix that soon.
In addition to the Jimmy Green video, which I’m sure is very good (I’m just not a Facebook fan), you can also get decent demos at Brummel Splice Demo | Demonstration | Animated Knots by Grog or https://youtu.be/dFCJa7tK51k . With both, the technique illustrated is best if you using stitching after to seize the eye tightly to the low friction ring.
-- Bob
Definitely a fun winter activity. It can get addictive, once you see how many variations are possible. Sort of like trying to bake the perfect loaf of bread.
For deadeyes there is also an approach that doesn’t require stitching, where you rebraid one of the tails to form a proper mobius brummel. Kinda interesting HERE.
Both methods work fine, braiding is tedious..
At the rendezvous Colle from SV Hippo showed me and approach that captures the low friction ring with and eye splice and left a tail that could be used to secure the ring where needed. In this instance the ring was going to be used for a tack reef line. I’ll try and grab a photo next time I’m on the boat. Below is a photo of the low friction ring in action. Ring is captured by a tight eye spliced in dyneema. We’ve left a long tail that allows for flexibility when lashing for various uses.
In this case the tail goes up through the reef rings ( see lower photo ) then back around the low friction ring. This particular iteration is flawed because the dyneema tail is too long and lands the same side of the slugs below the reef rings. Next iteration will have the reef line going up on one side of the lower slugs and down the other side. The low friction ring will be about 3" below the reef rings to allow ample clearance for the mainsail luff. I think the rings on this sail were meant to be hooked, but using a hook means you wouldn’t have a luff reef line in the cockpit. Someone would nee to go to the mast to hook the rings.
Maybe I’m missing something ?
Photo taken with sail reefed.
Rob…
I’m interested in using something like this for a 2:1 halyard. Has anyone done anything similar?
What sort of halyard ?
I’m not sure what’s going on in your photos . Im reasonably sure that the original reef design for the tack of the sail was simply to run the line from the cockpit through a block to the reef point on the tack (1st or 2nd) and tie a bowline knot.
What advantage is this dyneema ring , etc. maybe this is part of a ‘one line per tack ‘ reef system I’ve seen on some Nonsuches ?
Gary,
I like the original reef system design. Separate lines for luff and leach make sense to me, and if you have extra crew reefing can be done very fast.
Maybe I’m guilty of a solution looking for a problem.
My sail has a heavy strap fed through the reef cringle ( see bottom photo). Trying to understand why. Each end of the strap has a heavy metal ring larger than the ID of the cringle.
Originally (1st season) I thought, OK I’ll just tie the reef line through one of the rings instead of through the cringle which results in some chafe on the luff. This worked, but didn’t seem right because it relies on one of the rings being held by the cringle. With a lot of pressure the ring might deform the cringle ? Next I tied my bowline through both rings. This also worked but caused to chafe on the luff.
Then (2nd season) I thought of running the reef line through the cringle and back down to the collar that my tack shackle is attached to. This gives me a 2:1 purchase so it’s easy even when wind is resisting my effort to secure the luff reef point.
This worked, but left me asking myself why I have these heavy straps with rings sewn into the ends.
Then ( 3rd season) I thought maybe I could pull down on both rings independently using the low friction ring as as a “better” turning block than the cringle and minimize chafe.
This is where I am.
Like I said, I’ve probably over engineered this and go back to one of the earlier versions.
Rob…
I’d agree - simple is better.
