Good work, Rick. Glad to see you trying to save these old pumps.
What condition is the shaft? Could the shaft easily rotate before you had to break the carbon bushing apart? Maybe a silly question, but did you remove the C-clip?
The carbon bushing is your shaft bearing. Carbon bushings are used extensively in electric motors, and pumps. I suggest to use emery cloth to clean up the bore where the bushing belongs. The bushing should go in the housing with a little resistance, basically thumb pressure. The shaft needs to be clean, polished, free of burrs and gouges, as any of those mentioned conditions could either wear down the bushing quickly, or seize the shaft. The finest emery cloth you can obtain will be beneficial. We use to polish armature shafts with a rouge wheel, but not everyone has one of those hanging around,…so replacing the shaft would be a better option if there are any signs of damage.
You may find the bushing is oil impregnated so adding a little extra light weight oil will be fine. The shaft should easily slide, and rotate, inside the bushing.
Good luck.
Jack Dokter
Nine Lives, 26C W21 099
Penetanguishene, On
Hi Guys,
I got my raw water pump off today. It is indeed a Sherwood H70, although the cover says ITT Jabsco. I got it on the bench and tore into it. I got the oil side seal out easily. I couldn’t seem to pry out the seal on the water side, so I thought I would drive out the carbon bushing first. Well, turns out the carbon bushing is really soft, basically pencil lead. It just broke apart and didn’t drive out of the pump at all. Once I got the bushing out the water side seal removal was easy.
I found all the parts to reassemble the pump at at pumpvendor.com.
I don’t know how I’m going to drive in a soft carbon bushing into the pump housing without it shattering. It’s pretty fragile. I’m thinking oil it up and use a clamp or something to slowly push it in. Driving it in with a socket and hammer is for sure not the way to go…
A few pictures are attached. Oh, and my engine is a W21, not a 21A. I don’t know why I said in the title it was 21A because I know it’s not. Anyway…
