Water tanks & plumbing
Just discovered the fill is not attached to the original port tank. The forward tank is likely leaking. I’m sensing the tanks were not used much by the prior owner. I may be looking at replacing the tanks and plumbing. Are poly tanks available for a Nonsuch 30U?
Dan Mills
NS30U #460 sakina
West River, MD
These water tanks can normally be removed for inspection. New poly tanks are available on the INA website if needed.
Following up on Joe’s comment more specifically, sign on the www.Nonsuch.org website, click on the STORE tab and select TANK REPLACEMENT PROGRAM.
Thanks for this information.
