Can anyone tell me the amount of transmission fluid I can expect to to draw out from the Hurth HBW 100 and the total capacity. I have a topsider oil changer but wonder if there is a better pump for the ATF.
Paul: I changed mine this past winter and switched to synthetic ATF but don’t remember how much. However, I think it’s less then a quart. Using a pump with a small tube gets you down lower in the case. Make sure your tranny is warm prior to pumping the ATF out. Also, do not screw the dipstick in when checking the level. The above attachment is the Hurth manual.
