22’NS Table storage?
Good day everyone!
Where do we store the table on a 22’ NS when it is not set up??
Picture if you have them!
Hi there. On my NS22 the siding table is hinged to the bulkhead and clipped to the cabin ceiling for stowage. I will send you a photo tomorrow.
Charles
“Foggy” NS22 o/b #56
Typo - dining table
Mine is stowed in the head on the right of the toilet. It came like that from the factory. This way the table is not in the way. I only install it if I’m going to use it. It fits very well there, and is not in the way for flushing the toilet.
Note removable pins in bulkhead hinges - for mast access.
Thank you!! Just what I needed to know!
Norm, off topic, but where are you… Comox?
Breezin’ NS30U
Vancouver
Don,
I’m in Comox at the Municipal Marina on A-16
Norm
Nonsuch 22 White Wing
In my 30C, there is a fold down table attached to the door. It folds up, with a support to the door and then it can fold out to double the size, with a support to the floor. Probably custom from a previous owner. Frees up a lot of space when not in use and stored right there.
Same here. NS22 #8
Mine is also stored in this location in the head. The only problem I’ve noticed with this is that for a while the head pump intake had leaked, and water had been running around and accumulated under the end of the table. Failed to attend to that and had a mildew problem. All taken care of now, but might be worth putting a couple of PVC washers underneath the end as spacers to allow any water that may accidentally flow in there to escape rather than sit there and stew.
Great idea! Thank you!
Two Discourse things -
1 - if you look at that faint row of icons along the bottom of a post, the first one (a check mark in a box) is for “Solved”. If you have your answer, you can click on that. It does not stop further discussion.
2 - I am going to move the topic to the Questions and Answers category - a little housekeeping. It will behave the same on the home page, and you can of course find it months from now by searching for “table”, etc.
