Barient 17 winch retaining nut
Our mainsheet winch retaining nut came loose while sailing.
It would seem I was successful at keeping the winch intact and getting it locked down.
But I noticed that if I tighten the nut fully, the winch locks down and can not turn.
Is that normal?
Looking at notes on the archive and the diagram of the parts, it would seem possible that if the drum bearing lifted off, the pawls and springs may have fallen out?
Given this occured while doing a “round-about” maneavor I admit I was a bit distracted by the whole assembly liffing into the air while hauling the sheet.
If the parts are lost, would it make sense to take our current Barient 19 from the port side and use as a replacement for the sheet then plan to upgrade that to a stronger two speed winch?
We lift the sail having a crew member go forward and haul, but would seem a stronger winch might help with this task?
I have read the notes and while it is possible we have track resistance playing a role in lifting the sail assuming we have that under control, what would a stronger winch recommendation be?
Thanks, enjoy the knowledge I gather from this list.
Curt Danforth
Benefit 26C
Hi Curt,
I have the 19ST Barient winch for the halyard and I replaced the sheet winch with a Anderson 28 2speed ST.
After investigation the old Power Ratio of the Barient was more than the Anderson 28 which I had from previous boat.
Here is the ratio’s of each
Barient 19
gear ratio- 1st 2.3:1 2nd- 5.3:1
Power ratio-15.3:1 35.3:1
Anderson 28
Power ratio-9.5:1 26.6:1
I am happy with the 28 for the sheet winch and if I change out the Barient 19, it will be with Lewmar 30 or 40.
The Barient 19 works OK but I have the strong track and Craftsman electric drill for help.
Hope this helps,
Frank A.
Galene #166 26C
Winthrop, Ma.
Was looking for WHEN this problem last occurred and this posting was my clue.
We did swap the Barient 19 halyard winch in for the failed main sheet winch in 2013 and now it too has failed.
Given the winch has been in use since 1985 I guess we can not complain.
The plan will be to purchase a Lewmar of similar size as the replacement.
Curt Danforth
Benefit 26C
Masons Island, Mystic CT
What, in particular failed, Curt??
The winch started locking up while turning and would only turn if I unscrewed the locknut to get it loose and moving again.
Curt Danforth
Benefit 26C
I guess it’s not possible to recondition?? Cleaning, replacing any worn parts and lubrication won’t work??
In 2009 I replaced my Barient winch with a Lewmar electric 40ST ELS. Pushing the button and watching the sail go up is a real pleasure when I am single handing. In 1994 Harris and Ellis put out the attached bulletin on installing the Lewmar 40 electric winch on a Nonsuch. It has good winch operating tips.
Installing my Lewmar winch was straightforward although the bolt hole patterns were different from the Barient. The area under the winch is plywood so I filled the old holes with epoxy then drilled the new bolt pattern. You have to be careful not to over tighten the bolts against the plywood. I tightened the bolts then checked them after a few weeks of use, and applied Loctite. Lewmar recommends the line should enter the winch at -5 to -10 degree angle so to get this angle, I installed a beveled washer under the winch.
John Barbour
Nature 26U
Harris and Ellis update- Nonsuch - Lewmar winch 1994.pdf (2.44 MB)
