Has anyone found a replacement mainsheet winch for a 33 that has the same bolt pattern as the stock one that came with the boat?
Last year I was experiencing a skipping action every several turns of the winch handle in the original Barient sheet winch on my Nonsuch 33 #8. I found a deal on a new Lewmar 44 self tailing winch on EBAY. The bolt pattern is not the same as the original but the winch fits the space and works great.
You might take a look at Hutton Winches in Australia: https://www.huttonwinches.com/
In addition to stocking a lot of Barient replacement parts that may make your winch usable again, I have the impression that their own Hutton winches are built based on Barient designs.
You should verify that with them, but if I’m correct, then they may match the original hole patterns.
Prior to current tariff complexities, they were very fast and responsive both in responding to communications and in getting stuff to the U.S. Americans may find that this has changed. Canadians will probably find no differences from the past.
-- Bob
