Has anyone installed a garboard drain plug in their bilge? Thoughts on installing one?
Val
NS26C #75
Val
NS26C #75
Hey Val;
If you are worried about winter storage, and you have a depth or knot meter that can be removed for cleaning, remove one of these.
They might not be at the bottom of the bilge, but close enough to protect your woodwork in case of issue. I know my knot meter comes out quite easily.
I’d want to put something so that mice could not use it as an entry point, though. (mesh netting??)
John NS26C 046 - she’s sitting out of harms’ way at Bath, ON for the winter.
When I did this, I rolled a paper towel and inserted into the hole far enough to be easily seen from the outside to ensure that the boat was not accidentally launched in the sprin
Carl Linkinhoker
NS26C, 146, Break of Day
Mayfield, NewYork
