Perfect! Exactly what I was looking for.
Thank you very much, truly appreciated.
Best,
Jerry
Jerry,
It’s not covered in the manual, which also specifies the blocks you need on four assumptions that many owners don’t accept: (1) that the topping lift control will terminate on the cleat on the wishbone; (2) that no one ever wants to adjust the topping lift with the boat in motion; (3) we all are possessed of superhuman strength; and, (4) single blocks give you enough leverage.
Here’s how I ran mine.
If you look closely at the “Solar Wind ringging (9)”, you can see that I used two fiddle blocks, one with a shackle and one with a becket and a shackle, instead of single blocks. You’ll also spot holes filled in where the cheek block (and, not shown, the cleat) were removed from the wishbone. To run the topping lift line forward along the wishbone, I used a small block attached to a soft shackle to turn the topping lift line so it could run on the underside of the starboard part of the wishbone. There’s a different kind of fiddle block that’s better if you choose to keep using the cheekblock on the outer side.
Below are the GarhauerMarine.com part numbers for both approaches.
Topping Lift Purchase Blocks at aft end of boom
One fiddle block with becket and shackle (goes at end of topping lift pennant) PLUS one Fiddle block with shackle (attaches at aft end of boom):
Either one Garhauer 30-02 Series plus one 30-01 Series OR one 40-02 Series with one 40-01 Series (choice depends on topping lift turning block used)
Topping Lift Turning Block at aft end of boom
Originally a cheekblock on wishbone aft starboard outerside; some prefer a block w/ shackle attached to aft boom end between the two boom pieces.
If upgrading the cheek block, consider using a Garhauer 30-21 Stainless Steel cheekblock, although it will require a pad to adapt to the boom curvature. If replacing it with a block to go between the wishbone pieces (as in the picture), use a Garhauer 30-13 Series single block with a soft shackle.
Boom lead blocks for aft 2nd reef and topping lift control line
This is a double block w/ shackle hanging from the forward end underside of the starboard wishbone half. A suitable Garhauer block is one from their
30-17 Series .
Hope this is helpful.
Solar Wind
Nonsuch 26C #143
