Hi All -
Thank you again for all of the guidance, opinions, questions posted about new lifelines. It was all very helpful.
A mid-process update:
After many measurements, and re-measurements, analysis of the situation, aesthetics, costs, DIY capabilities, and COVID-19 delays (I received 0 responses from the multiple companies to whom I sent measurements/inquiries to have lifelines professionally fabricated), I decided to go with the SUNCOR Quick Attach system. Defender had the best pricing, and they are still fulfilling orders. If you are not a Defender 1st Member - sign up!! it costs nothing and in many cases can save quite a few dollars! I ordered Saturday evening, the order is arriving this evening (72 hours).
I was leaning toward Dyneema/Amsteel rope lifelines - however, surprisingly, the cost was the about the same as traditional lifelines when all of the necessary parts were accounted for (not reusing any existing hardware), the longevity of the rope is considerably shorter (though only the rope should need replacing in 4 to 5 years - no hardware), and my splicing skills (if we want to call it skill) is suspect as I hadn’t made an eyesplice or any other kind of rope splice in probably 25 years. There are good videos on how to make splices and particularly with Dyneema, Amsteel, and Spectra lines on YouTube, but I would have to make 24 splices - which to me sounded like a lot, and if one of them was not up to quality, it could potentially be life-threatening at some point. I did find my old fid and ‘pusher’ from when I took a course on splicing!
So, with cost seemingly almost the same for each variation, the Suncor Quick Attach looks to be the easiest, no special tools required, and simple enough for me to do it by myself, without having to wait for a rigging shop to produce the new lifelines, or for me to have to send them my old lifelines to copy.
The hardware is all 316 Stainless, and looks robust enough to properly do the job. The hardware may appear a bit bulky, but I would rather have a little bulky than a flimsy feel. The reviews that I found that covered the last 10 years leaned very heavily on the positive side.
All of the parts are now Made in the USA, so hopefully quality control is higher, but that may not always be the case, but I prefer to buy USA/Canadian products if possible.
I opted to buy the same vinyl coated 3/16th inch 316 stainless wire rope (7x7) with a coated diameter of 5/16th’s inch, as I am accustomed to the size/feel in my hand. I rarely ever race so coated vs uncoated doesn’t play into this decision, and I know to inspect frequently. The lines I am replacing are my original lines, so 33 years old, and I should have replaced them a few years ago (ok… more like 20 years ago!)… So, even if I get 10 years of life from the new lines, and then need to replace the wire rope, the replacement cost will not be high as all of the Quick Attach fittings from Suncor are reusable.
The only tool I don’t have is a wire-rope cutter, which a couple of my marina neighbors offered to lend to me. Apparently, my hacksaw makes a nice, clean, easy cut through the old lifelines (I tested), so I do not need to buy a cutter just for this project.
I will post photos, and video (possibly) after completing the removal of the old and installation of the new lifelines.
Stay safe!!
1987 30 Ultra 430
