Does anybody know the weight of the mast in a NS 30? I am guessing close to half ton. Reason is our club’s mast crane has seen many a year and I would prefer to raise the mast rather than the lower the crane.
Along the same lines, what’s a NS30C weigh as it sits at the dock? Data sheets say 4.76 tonnes, crane operator said 7.2 tons (dry, wishbone, no mast), registration plate says 10.25 (tons max?). These vary a lot.
That seems high to me. Seem to remember hearing weight is more like 350 lbs but not sure of source.
David Young
Bay Cat, 30U #402
I put the mast in the 300 lb range. BIANKA weighed 16,000 lbs in the sling.
Sent: Wednesday, October 31, 2018 2:59 PM
To: INA Nonsuch Discussion Group
Reply To: INA-Nonsuch-Discussion-Group@googlegroups.com
Subject: NS30 Spar Weight
16,000 pounds! 16,000 pounds! That is eight tons or 7.27 metric tons. Good thing that electric motor is so light. Of course La Reina comes in at 9500 to 10000 pounds when lifted, not the 8500 shown in the brochure.
La Reina 26C ( for chubby)
Vancouver, B.C.
Might be apocryphal, but I read somewhere that the design displacement of the 30 was ~11,500 pounds but George Hinterhoeller refused to build them that skinny so most of them came out of the shop several thousand pounds more than that.
David Young
Bay Cat, 30U #402
The calculated weight of the spar (AKA mast) is 150kg or 350lbs. Attached are the calculations, using online calculators. This is lower than calculating by hand (226kg) so I will ask the crane operator tomorrow, assuming he doesn’t get all uppity again.
~Mast weight calculations.txt (1.27 KB)
Perhaps you haven’t allowed for the sleeve inside.
Dick
NS26c Swoose
Our 26 comes in at 9500 plus boom, mast, water and ships stores... my guess is that we leave the dock at 10500
Al,
The brochure for the 324 states the the carbon fibre mast on the 324 saves 200 lbs. I am thinking the aluminium would be in 500 to 600 lb range. Tartan claims their carbon fibre mast weighs 50% less then aluminium. I have read numbers ranging from 20% to 50% in weight savings. If carbon saves 50% or 200 lbs the the aluminium would weigh 400 lbs. If it only saves 20% the the aluminium 30 mast would be 1000 lbs. which seems high to me. That is why I am thinking 500 to 600 lbs with 400 at the lowest.
Mike Quill or the people at Klacko should be able to give you a more reliable number. Klackospars.com will take you to their website.
La Reina 26C
Vancouver, B. C.
I asked Mike Quill about a NS30 spar, he says “The tubes only weight is listed at 232 lbs. I would add another 125 lbs for hardware, castings etc”. That is 357 lbs (162kg) which is in the calculated range.
Alan “Corvus”
Danny at Klacko Spars says “The tube weight from manufacturing estimated 384 and easy to add another 100 lbs for hardware. so a complete rig you are about 500 lbs”. The plot thickens.
Alan “Corvus”
So somewhere between not very heavy and really quite heavy ... give or take a little.....
Right?
NS 30U #211 Sandpiper
Cowichan Bay B.C.
Paul,
I don’t think the estimates are quite that accurate. More like somewhere between not too heavy and way too heavy, give or take a lot. I think we can reliably assume the mast and boom weight less then the complete boat.
La Reina 26C
Vancouver, B.C.
I have noticed that the mast gets heavier every year when I pull it and then put it back in the spring.
It does give me a chance to inspect it, give it preventive maintenance and be confident out on the water that it will take heavy weather in stride…
Brian McCuaig. NS30u
Whitby, Ontario
“Having a yacht is reason for being more cheerful than most." -Kurt Vonnegut
