Oil change for a Universal M-35B four stroke diesel
If you change the oil on a Universal M-35B, could I talk to you about the process? I’m about to do it for the first time.
Dan Mills
NS30U #460 sakina
West River, MD.
Dan: Is there a hose going to the bottom of the engine?? If so, you can use that to pump the drain oil into a container for proper disposal. Usually, the messiest problem is removing the oil filter. I’m sure there are videos of how to change horizontally mounted filters. Have plenty of oil absorbent rags handy.
