Photo or vendor of keel bolt torque wrench useful for Nonesuch
Is there place where I can see a photo of one or a vendor with photos? Yard here does not know about them.
Richard Westin, Intuition IX. Bahamas
I borrowed one very similar to this one.
Worked great. You’ll need some socket extensions, a breaker bar, and some wood block to bear against. ( HERE ) is a photo showing the bulkhead and floor stringers over the keel bolts. The wood block needs to be the right thickness to hold the socket extension vertical as you torque. I notched the block so the extension wouldn’t slide.
Good luck,
Rob…
