Replacing the Choker Cheek Block
I don't know if it was 25 years of the wishbone tapping the cheek
block on the mast of the Puffin (Nonsuch 22, hull #55), but the block
that runs the choker line from the aft end of the wishbone down the
mast fell apart while I was crossing a ferry wake in the San Juan
Islands last week.
The four screws were unbelievably tight - even with an impact driver,
two of them sheared! But eventually I got all four out. The brand on
the cheek block is Garhauer. Nobody seems to carry them here in
Victoria. Other cheek block models do not have the screw holes in the
right spots and I suspect that Garhauer might be higher quality than
many of the others.
Any suggestions on whether I should hold out for Garhauer or try to
customize another brand? Any tips on installation of the replacement
cheek block?
You can order direct from Garhauer - I have worked with them a few years ago - no problems
Safe Sailing
Cedric and Anna Single Malt 26C #207
Chester NS
I replaced that block several years ago with a swiveling one, fabricated by
Murray Cressman, which provides a fairer lead when broad reaching or
running. I believe there is a link to his products on the INA website. You
should also be able to obtain an exact replacement for the original block
from Murray, Mike Quill (also linked to from the INA websitge) or directly
from Garhauer. I have had excellent results dealing with all of them. Good
luck.
The US office is in California 909-985-9993 or email
garhauer@garhauermarine.com Lots of info available at their website
www.garhauermarine.com
Larry Jack 30U 261 'Felina'
Or, contact Mike Quill through INA.
Larry
Check with Mike Quill. Had the same on my 26 #162 last fall. Has a deluxe
one with stainless body and but a plastic roller.
Cost thought.
Charles
Very satisfied with Mike Quill. Had the same on my 22 #27 last fall.
Roger
Got my replacement block from Mike Quill as well about ten years ago. No problems at all.
— On Mon, 5/16/11, Roger Mongeau roger.mongeau@cgocable.ca wrote:
> From: Roger Mongeau roger.mongeau@cgocable.ca
> Subject: Re: Replacing the Choker Cheek Block
> To: ina-nonsuch-discussion-group@googlegroups.com
> Date: Monday, May 16, 2011, 12:16 PM
> Roger
> ----- Original Message ----- From: “Charles A. Webb” <cawebb@frontier.com>
> To: <ina-nonsuch-discussion-group@googlegroups.com>
> Sent: Sunday, May 15, 2011 11:04 PM
> Subject: RE: Replacing the Choker Cheek Block
> > Cost thought.
> > Charles
> > -----Original Message-----
> > From: ina-nonsuch-discussion-group@googlegroups.com
> > [mailto:ina-nonsuch-discussion-group@googlegroups.com] On Behalf Of
> > Larry/Sheila Jack
> > Sent: Sunday, May 15, 2011 5:13 PM
> > Larry
> > [mailto:ina-nonsuch-discussion-group@googlegroups.com] On Behalf Of Ben van
> > Drimmelen
> > Sent: May-15-11 5:10 PM
> > To: INA Nonsuch Discussion Group
> > Cc: steve.chatwin@gmail.com
> > Subject: Replacing the Choker Cheek Block
> > I don’t know if it was 25 years of the wishbone tapping the cheek block on
> > the mast of the Puffin (Nonsuch 22, hull #55), but the block that runs the
> > choker line from the aft end of the wishbone down the mast fell apart while
> > I was crossing a ferry wake in the San Juan Islands last week.
> > The four screws were unbelievably tight - even with an impact driver, two of
> > them sheared! But eventually I got all four out. The brand on the cheek
> > block is Garhauer. Nobody seems to carry them here in Victoria. Other cheek
> > block models do not have the screw holes in the right spots and I suspect
> > that Garhauer might be higher quality than many of the others.
> > customize another brand? Any tips on installation of the replacement cheek
> > block?
By way of Cc to Mike Quill I trust he may be able to help you with a
replacement, I know he carries a replacement chocker cheek block. Here's his
website: www.mqyr.com, and email: mquill@cogeco.ca.
Regards,
Dick (& Shirley) Darrow
"Cativa" NS30U #496
Sodus Bay, Lake Ontario USA
Hi
Check with Mike Quill and Murray Cressman
One of them offers a swinging block which fits the hole pattern of the cheek
block on the NS 30C and hopefully also fits the pattern on your boat.
Al
I’m about to put a new block on my new mast to take the choker line. Rather than try and replace it with a customised cheek block I’m going to attach an eye to the mast and hang a standard block from that. One advantage of this arrangement is the block will always be in line with the choker line.
Bob Illingworth
Nonsuch Luck 30U #367 Sail No K1262T
Gosport UK, Cruising area the Solent and the English Channel
