Syphon break
Morning everyone,
Attached is a photo of what I believe is a syphon break. I am sure it is original. It connects from the exhaust mixing elbow on my YANMAR 3GM30F and feeds into my exhaust outlet pipe.
It has a hairline crack which is leaking water very slightly.
Does anyone know who made them and if they are still available.
OR have you replaced it-what did you use? I am keen to use the existing unit’s footprint.
Many thanks,
Sean Curran
Merlin of Mersea # 489
BOSMBSC,
Somerset,
UK
Sean
That is a hydro hush muffler used to quiet the sound of the diesel engine exhaust.
biankablog.blogspot.com
Sean: The photo I’m looking at is of a waterlift muffler. They are readily available, just Google it. Make sure the small drain hole is not leaking. By the way, it may be easier to answer questions if we know what size and model your boat is via your signature.
![IMG_8666.jpg|737x1114](upload://qRPeLpyDmUhUXcoWqrtL6CaEbfd.jpeg)
Centek Vernalift mufflers are common on Nonsuches, and are readily available as a replacement.
Ed Cook
Chat-eau, N26C #173
Middle River, MD
I had the same problem before I converted to electric propulsion. Replaced mine with a Vectus. It is readily available and is made of plastic.
Jorgen Moller
Pondus NS26C #33
RCYC Toronto.
Thank you all, very helpful, I have found them on google now.
Sean Curran
Merlin of Mersea, #489, NS30U
BOSMBSC
Somerset,
UK
