Turning block
On our new boat, we realize we have a deteriorated turning block at the base of the mast. It is a Schaefer #30-56 double foot block
Can anyone suggest a good source for a replacement?
Thank you.
Bill Randall
s/v Helen K
NS30 #380
Miami,
FL
The company is in California and still making them , look them up and they can help!
Sorry
Swee’Pea
Nonsuch 22, #53
Joe Rogucki..
Try Mike Quill website - he has some NS22 blocks in stock.
Charles Fogden
“Foggy”
N/S 22 #56
Outer Harbour Marina
Thank you Joe, So far I’ve not been able to look them up, do you have any suggestions where I can find them?
Sorry I was thinking of the original blocks that came with my Nonsuch,
Bill,
I think most of the fleet came from the factory equipped with blocks made by Merriman Brothers. The company is no longer in business. If you are a member of the INA (if not consider joining) go to “Stores”, then select “Replacement Blocks” then select “Nonsuch 30 Replacement Blocks” The blocks with working loads are listed along with the Garhauer Minimum Equivalent. If you have a Schaefer and want to stick with that brand I am sure they can tell you the equivalent to the Garhauer.
I assume you are looking for a turning block near the base of the mast that is attached to the mast collar but not the halyard block. One used for reef lines, topping lift or choker. A picture of your current blocks would be helpful.
Thank you all for this great information, I am slowly learning to use this great resource.
Thank you
Bill Randall
NS 30U #380
Bill: It also helps to tell us where you are in your signature.
Regards,
I am sorry for that, Miami, FL
