The issues with solid wood go beyond the particular wood. There are actually some positives for plywood over solid wood sheets.
Quoting from Matweb.com, an on-line source on properties of different materials, “Plywood is made of several thin layers, or ‘plies’ that are laminated together. The layer structure leads to more uniform properties than solid wood, since the effects of grain anisotropy are minimized. The properties of plywood vary with the quality of the constituent layers…”
“Grain anisotropy,” is a fancy term for reactions to forces from different directions.
What this this adds up to is, if the plywood is of good enough quality, its resistance to forces acting on it is better than solid wood. Solid wood sheets, for example, can split along the grain if struck hard enough. Because the overlapping layers in quality plywood are oriented in different directions, the forces aren’t transmitted through the piece in the same way and the piece is less likely to split.
Modern glues have gotten to the point where high-performance aircraft are glued together rather than bolted or riveted. Several glues offer stronger-than-wood bonds; the piece will break where it’s NOT glued together rather than at the joint where the glue is. If the plywood is quality, the glue’s strong and water-resistant.
End grain balsa works in places where the forces acting on it can be assured to come mainly from a direction that works with the way its grain is aligned. That’s why it’s never used in high compression areas like where deck hardware will get bolted down hard. Where it’s appropriate to use, it’s effective and saves weight.
There are higher-tech coring materials which have all sorts of advantages (unfortunately, price NOT being one of them). If you want the absolute best and don’t mind spending money, they’re interesting to look into.
But, quality plywood remains a pretty good value from a cost/performance standpoint.
Solar Wind
Nonsuch 26C #143
