Batteries not charging
I noticed my voltmeter wasn’t working and my batteries are not charging. I’m assuming my alternator has failed. How should I test to see if my alternator is working? And, if it’s not working…should I replace or try to repair it?
Howard Whittaker
1982 N26 #18
Stray Cat,
Waupoos, ON.
Note: my engine is a 13 horse Westerbeke
Is that the voltmeter on your 12V electric panel?? Also, does your tachometer work when the engine is running??
~ ~ ~ ~ ~ (_ ~ (_ ~ (_ ~ ~ ~ ~ ~ ~ (_ ~ (_ ~ (_~ ~ ~ ~
It’s the meter beside the oil, water and tac (by the wheel under the starboard stern locker)…and no my tac isn’t working either (interesting you asked that question).
